Discuss
Whirlpool Gas Range - no gas to oven
 in
Hi! I have a Whirlpool Gas Range (Super Capacity 465, Model #SF302BEG). The range works fine. The oven will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Gas Range - no gas to oven
  #1 (permalink)
Old 07-02-2009, 03:18 PM
TCPerch TCPerch is offline
Junior Member
TCPerch is on a distinguished road
Default Whirlpool Gas Range - no gas to oven
Model Number: SF302BEG   Brand: Whirlpool   Age: 5 - 10 years
Hi! I have a Whirlpool Gas Range (Super Capacity 465, Model #SF302BEG). The range works fine. The oven will not start. The igniter glows nicely, but will not start. I don't hear the gas start, or smell any gas after it's been turned on for 30 seconds - this is why I don't suspect the igniter. Could it be a safety valve or something? And how would I troubleshoot this? Or does it sound like it may be best to call in a professional?
I really wouldn't have any issues with trying to troubleshoot it myself.
Thanks! TC
Related Models
Whirlpool SF302BEGN0
Whirlpool SF302BEGN1
Whirlpool SF302BEGW0
Whirlpool SF302BEGW1
Whirlpool SF302BERW0
Whirlpool SF302BERW1
Whirlpool SF302BERW2
Whirlpool SF302BERW3
Whirlpool SF302BERW4
Whirlpool SF302BERW5
Whirlpool SF302BERW6
Whirlpool SF302BEWN1
Whirlpool SF302BEWW0
Whirlpool SF302BEWW1
Whirlpool SF302BEYN0
Whirlpool SF302BEYQ0
Whirlpool SF302BEYQ1
Whirlpool SF302BEYW0
Whirlpool SF302BSAN0
Whirlpool SF302BSAN1
Whirlpool SF302BSAN2
Whirlpool SF302BSAW0
Whirlpool SF302BSAW1
Whirlpool SF302BSAW2
Whirlpool SF302BSEN0
Whirlpool SF302BSEW0
Whirlpool SF302BSGN0
Whirlpool SF302BSGN1
Whirlpool SF302BSGW0
Whirlpool SF302BSGW1
Whirlpool SF302BSKN0
Whirlpool SF302BSKW0
Whirlpool SF302BSKW1 30" Gas Freestanding Standard Clean Range Pilot Ignition
Whirlpool SF302BSRW0
Whirlpool SF302BSRW1
Whirlpool SF302BSRW2
Whirlpool SF302BSRW3
Whirlpool SF302BSRW4
Whirlpool SF302BSRW5
Whirlpool SF302BSRW6
Whirlpool SF302BSWW0
Whirlpool SF302BSWW1
Whirlpool SF302BSYN0
Whirlpool SF302BSYN1
Whirlpool SF302BSYW0
Whirlpool SF302BSYW1
Whirlpool SF302EERW0
Whirlpool SF302EERW1
Whirlpool SF302EERW2
Whirlpool SF302EERW3
Whirlpool SF302EERW4
Whirlpool SF302EERW5
Whirlpool SF302ESPW0
Whirlpool SF302ESRW0
Whirlpool SF302ESRW1
Whirlpool SF302ESRW2
Whirlpool SF302ESRW3
Whirlpool SF302ESRW4
Whirlpool SF302ESRW5
Whirlpool SF303PEGQ0
Whirlpool SF303PEGQ1
Whirlpool SF303PEKQ0
Whirlpool SF303PEKQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKQ2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKT0
Whirlpool SF303PEKT1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKW0
Whirlpool SF303PEKW1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEKW2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF303PEPQ3 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF3040SRW0
Whirlpool SF3040SRW1
Whirlpool SF3040SRW2
Whirlpool SF3040SRW3
Whirlpool SF3040SRW4
Whirlpool SF3040SRW5
Whirlpool SF3040SRW6
Whirlpool SF3040SWW0
Whirlpool SF3048EPW0
Whirlpool SF304BEPW0
Whirlpool SF304BSAG0
Whirlpool SF304BSAN0
Whirlpool SF304BSAN1
Whirlpool SF304BSAW0
Whirlpool SF304BSAW1
Whirlpool SF304BSPW0
Whirlpool SF304BSWW0
Whirlpool SF304BSWW1
Whirlpool SF304BSYG0
Whirlpool SF304BSYG1
Whirlpool SF304BSYN0
Whirlpool SF304BSYN1
Whirlpool SF304BSYW0
Whirlpool SF304BSYW1
Whirlpool SF304PEEN0
Whirlpool SF304PEEQ0
Whirlpool SF304PEEW0
Whirlpool SF305BEWN0
Whirlpool SF305BEWN1
Whirlpool SF305BEWQ0
Whirlpool SF305BEWQ1
Whirlpool SF305BEWW0
Whirlpool SF305BEWW1
Whirlpool SF305BSWN0
Whirlpool SF305BSWN1
Whirlpool SF305BSWW0
Whirlpool SF305BSWW1
Whirlpool SF305EERW0
Whirlpool SF305EERW1
Whirlpool SF305EERW2
Whirlpool SF305EERW3
Whirlpool SF305EERW4
Whirlpool SF305EERW5
Whirlpool SF305ESPW0
Whirlpool SF305ESRW0
Whirlpool SF305ESRW1
Whirlpool SF305ESRW2
  #2 (permalink)
Old 07-02-2009, 08:35 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
The igniter can be bad even if it glows. You have to measure the current drawn by the igniter. If it's 3.2 amps or less then the igniter is the culprit.
- The part number for the oven igniter is AP3135265
__________________
  #3 (permalink)
Old 07-03-2009, 01:02 PM
Junior Member
Default Does the igniter regulate the gas?
So, quick question then... Does the igniter regulate the gas as well as ignite? Because I wasn't getting any gas. I assumed I would.
I did take a look, and while I was behind the range I unplugged it. When I plugged it back in it worked again. I'm assuming this will be a temporary fix though. If the igniter does affect gas flow, then I will go ahead and assume it is the igniter, since I don't have a multimeter to check the amps.
Thanks. TC
  #4 (permalink)
Old 07-03-2009, 02:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can learn how the oven igniter works from one of our previous posts: Oven won't lite?
__________________
  #5 (permalink)
Old 07-03-2009, 05:40 PM
Junior Member
Default
Thanks Gene. That does help. I didn't know the two were that closely integrated, but I guess it makes sense for safety reasons.
I will look into replacing the igniter then. It seems like it shouldn't be too difficult to replace.
TC
  #6 (permalink)
Old 07-03-2009, 09:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore range by Whirlpool - oven won't light chingliu Oven Repair (including Ranges and Cooktops) 27 09-23-2009 06:10 PM
Whirlpool Oven top range works, oven not sportsfandallas Oven Repair (including Ranges and Cooktops) 10 07-20-2009 10:19 PM
Whirlpool Range/Oven TomWski Oven Repair (including Ranges and Cooktops) 3 05-29-2009 05:39 PM
Whirlpool Gas Range Oven/Broiler No Ignition Bud29 Oven Repair (including Ranges and Cooktops) 1 09-09-2008 07:06 AM
Whirlpool SF357PEKW range works oven doesn't dr00bie Oven Repair (including Ranges and Cooktops) 0 07-10-2008 12:50 PM
