Discuss
Problems after self clean mode
 in
I used the self clean feature yesterday. During the self cleaning my oven shutdown and the control panel went blank.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Problems after self clean mode
  #1 (permalink)
Old 07-01-2009, 09:04 PM
Charles1964 Charles1964 is offline
Junior Member
Charles1964 is on a distinguished road
Default Problems after self clean mode
Model Number: RBS305PDQ12   Brand: Whirlpool   Age: 5 - 10 years
I used the self clean feature yesterday. During the self cleaning my oven shutdown and the control panel went blank. Leaving the oven dead and the door locked. I could smell that something electrical had burned out. I removed the outside portion of the door and was able to push the hook over and unlock the door. Once I got to the control panel I could see that one of the components on the back had burned out. I located a new control panel for $180.00 and installed it. The new control panel came with a suppressor board. The instructions showed how to install it on the oven's terminal panel but gave no other information. I figured it was an improvement that came out on later models and installed it. After installing the new control panel and suppressor board everything looked like it was back to normal at first. Then I noticed that the oven wasn't getting hot. I set the oven to bake at 350 degrees and the control panel showed preheat mode and the counter counted down but the heating element never got hot. Is the new control panel defective, should I remove the suppressor board or is there another problem?
Related Models
Whirlpool RBS305PDQ12
Whirlpool RBS305PDQ13
Whirlpool RBS305PDQ14
Whirlpool RBS305PDQ16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ2
Whirlpool RBS305PDQ4
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT8
Whirlpool RBS305PDT9
Whirlpool RBS305PDZ1
Whirlpool RBS305PDZ10
Whirlpool RBS305PDZ2
Whirlpool RBS305PDZ4
Whirlpool RBS305PDZ6
Whirlpool RBS305PDZ8
Whirlpool RBS305PDZ9
Whirlpool RBS305PRB00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRQ00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRS00 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PRT00 30" Built - in Electric Oven Self Clean
Whirlpool RBS307PDB1
Whirlpool RBS307PDB2
Whirlpool RBS307PDB4
Whirlpool RBS307PDQ1
Whirlpool RBS307PDQ2
Whirlpool RBS307PDQ4
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B Commercial Microwaves
Amana RC-10B-DD Commercial Microwaves
Amana RC-10B-PB Commercial Microwaves
Amana RC-10D Commercial Microwaves
Amana RC-10PB Commercial Microwaves
Amana RC-10S Commercial Microwaves
Amana RC-10SD Commercial Microwaves
Amana RC-10SE Commercial Microwaves
Amana RC-14 Commercial Microwaves
Amana RC-14B Commercial Microwaves
Amana RC-14S Commercial Microwaves
Amana RC-14SD Commercial Microwaves
Amana RC-14SE Commercial Microwaves
Amana RC-14T Commercial Microwaves
Amana RC-14TD Commercial Microwaves
Amana RC-14TE Commercial Microwaves
Amana RC-20 Commercial Microwaves
Amana RC-20SE Commercial Microwaves
Amana RC-6D Commercial Microwaves
Amana RC-6PB Commercial Microwaves
Amana RC-7D Commercial Microwaves
Amana RC-7PB Commercial Microwaves
Amana RC-8 Commercial Microwaves
Amana RC04880A1D Room Air Conditioner
Amana RC04880A1D REV Room Air Conditioner
Amana RC04880A1DR Room Air Conditioner
Amana RC04880A1DR REV Room Air Conditioner
Amana RC04880A1E Room Air Conditioner
Amana RC04880A1X Room Air Conditioner
  #2 (permalink)
Old 07-01-2009, 11:50 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question No 240 volts?
The elements operate on 240 volts, all the rest of the appliance on 120 only. Your symptom could just be caused one leg of the power supply not getting to the appliance. Check and/or reset the breakers and/or confirm the full 240 volts is getting to the appliance.
There is also a safety thermostat (see the following link) that looks to be in series with both bake and broil elements. If it has failed it might cause just the element to cease to operate. It might trip during a self clean cycle.
LINK > Whirlpool RBS305PDQ12 Safety Thermostat
That may be a possibility but only a very slight one IMO.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 07-02-2009, 06:23 AM
Junior Member
Default
There is only one circuit breaker to the oven and I reset it but no change. The safety thermostat sounds like a good possibility.
Thanks!
  #4 (permalink)
Old 07-06-2009, 10:06 AM
Junior Member
Default
I replaced the safety thermostat and the oven is back up and running.
Thanks!
  #5 (permalink)
Old 07-06-2009, 03:45 PM
Senior Expert
APP Volunteer
Thumbs up Fixed!
Quote:
Glad to hear it, thanks for the follow up.
Dan O.
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE oven stuck in self-clean mode mmuratet Oven Repair (including Ranges and Cooktops) 1 05-17-2009 04:26 PM
Ice maker won't enter clean mode guy441 Refrigerator & Freezer Repair 0 02-13-2009 03:32 PM
oven won't light,clean mode works fine lparrack Oven Repair (including Ranges and Cooktops) 0 01-18-2009 10:17 AM
Jen-Air Cycling on Off in Clean Mode + Clock toddmccracken Oven Repair (including Ranges and Cooktops) 0 07-03-2008 11:40 AM
F1 failure code in self clean mode only scruffydog Oven Repair (including Ranges and Cooktops) 10 12-27-2007 12:24 PM
