Intermittant trouble with the sparking system in the past has culminated today in no burners lighting at all. I cannot smell or match-light gas, so I assume it is the Pressure Regulator (part number AP3032662). (The valve on incoming line is open.) However, could it also be on the electrical side -- some valve closure fault? Regulator ($35) and Spark Module ($130) are available online, but this is a 20-year-old stove top -- so is it time for replacement vs. repair? Craig
