The igniter on my Ge Profile slide in gas range won't stop sparking and I need to replace the harness switch which is around the burner controls under the front panel. How do I get the front panel off? There seems to be some screws under it and holding in the trim pieces but it won;t budge. Do I need to take the glass top off?
