Discuss
Is replacing the clock on a Tappan range a DIY project?
 in
Our Tappan range is about 5 yrs old and the oven stopped heating a few months ago. Sometimes it would
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Is replacing the clock on a Tappan range a DIY project?
  #1 (permalink)
Old 07-01-2009, 06:50 PM
sonyajo sonyajo is offline
Junior Member
sonyajo is on a distinguished road
Default Is replacing the clock on a Tappan range a DIY project?
Model Number: TGF336AWD   Brand: Tappan   Age: 1 - 5 years
Our Tappan range is about 5 yrs old and the oven stopped heating a few months ago. Sometimes it would heat but then go out when you had something baking. It has been flashing error code F1, which according to the owners manual, means the clock needs to be replaced. Is this something the average person could do on a weekend?
Related Models
Tappan TGF336AWD Tappan/gas Range
Tappan TGF336AWE Tappan/gas Range
Tappan TGF336AWF Tappan/gas Range
Tappan TGF336AWG Tappan/gas Range
Tappan TGF336AWH Tappan/range
Tappan TGF336AWJ Tappan/range
Frigidaire TGF336BHDA Tap(v1) / Gas Range
Frigidaire TGF336BHDB
Frigidaire TGF336BHDC
Frigidaire TGF336BHDD Gas Range
Tappan TGF336BHDE Tappan/gas Range
Frigidaire TGF336BHSA Tap(v2)
Frigidaire TGF336BHWA Tap(v2) / Gas Range
Frigidaire TGF336BHWB
Frigidaire TGF336BHWC
Frigidaire TGF336BHWD Gas Range
Tappan TGF336BHWE Tappan/gas Range
Frigidaire TGF336CHSA Tap(v3) / Gas Range
Frigidaire TGF336CHSB Tap(v1) / Gas Range
Frigidaire TGF336CHSC Tap(v2) / Gas Range
Frigidaire TGF336CHSD Gas Range
Tappan TGF336CHSE Tappan/gas Range
Tappan TGF336FSA Tappan/range
Tappan TGF336FSB Tappan/range
Tappan TGF336FWA Tappan/range
Tappan TGF336FWB Tappan/range
Tappan TGF350MXDSA Tappan/gas Range
Tappan TGF350MXDSB Tappan/range
Tappan TGF350MXDSC Tappan/range
Tappan TGF350MXDSD Tappan/range
Frigidaire TGF350SCWA Tap(v0) / Gas Range
Frigidaire TGF350SCWB Tap(v0) / Gas Range
Frigidaire TGF350SCWC Tap(v0) / Gas Range
Frigidaire TGF350SCWD Tap(v0) / Gas Range
Tappan TGF351AWA Tappan/range
Tappan TGF351AWB Tappan/gas Range
Tappan TGF351AWC Tappan/gas Range
Tappan TGF351AWD Tappan/gas Range
Tappan TGF351AWE Tappan/gas Range
Tappan TGF351AWF Tappan/gas Range
Tappan TGF351ESA Tappan/range
Tappan TGF351ESB Tappan/range
Tappan TGF351ESC Tappan/range
Tappan TGF351ESD Tappan/range
Tappan TGF351ESE Tappan/range
Tappan TGF351ESF Tappan/range
Tappan TGF351SHWB Tappan/gas Range
Tappan TGF351SHWC Tappan/gas Range
Frigidaire TGF353BCDA Tap(v1) / Gas Range
Frigidaire TGF353BCDB Tap(v1) / Gas Range
Frigidaire TGF353BCDC Tap(v1) / Gas Range
Frigidaire TGF353BCDD Tap(v1) / Gas Range
Frigidaire TGF353BCWA Tap(v2) / Gas Range
Frigidaire TGF353BCWB Tap(v2) / Gas Range
Frigidaire TGF353BCWC Tap(v2) / Gas Range
Frigidaire TGF353BCWD Tap(v2) / Gas Range
Frigidaire TGF354SCDA Tap(v1) / Gas Range
Frigidaire TGF354SCDB Tap(v1) / Gas Range
Frigidaire TGF354SCDC Tap(v1) / Gas Range
Frigidaire TGF354SCDD Tap(v1) / Gas Range
Frigidaire TGF354SCWA Tap(v2) / Gas Range
Frigidaire TGF354SCWB Tap(v2) / Gas Range
Frigidaire TGF354SCWC Tap(v2) / Gas Range
Frigidaire TGF354SCWD Tap(v2) / Gas Range
Frigidaire TGF355BCDA Tap(v1) / Gas Range
Frigidaire TGF355BCDB Tap(v1) / Gas Range
Frigidaire TGF355BCDC Tap(v1) / Gas Range
Frigidaire TGF355BCWA Tap(v2) / Gas Range
Frigidaire TGF355BCWB Tap(v2) / Gas Range
Frigidaire TGF355BCWC Tap(v2) / Gas Range
Frigidaire TGF355BEDA Tap(v1) / Gas Range
Frigidaire TGF355BEDB Tap(v1) / Gas Range
Frigidaire TGF355BEDC Tap(v1) / Gas Range
Frigidaire TGF355BEWA Tap(v2) / Gas Range
Frigidaire TGF355BEWB Tap(v2) / Gas Range
Frigidaire TGF355BEWC Tap(v2) / Gas Range
Frigidaire TGF355BFDA Tap(v1) / Gas Range
Frigidaire TGF355BFDB Tap(v1) / Gas Range
Frigidaire TGF355BFWA Tap(v2) / Gas Range
Frigidaire TGF355BFWB Tap(v2) / Gas Range
Frigidaire TGF355BHDA Tap(v1) / Gas Range
Frigidaire TGF355BHDB Tap(v2) / Gas Range
Frigidaire TGF355BHDC Tap(v3) / Gas Range
Tappan TGF355BHDF Tappan/gas Range
Frigidaire TGF355BHWA Tap(v4) / Gas Range
Frigidaire TGF355BHWB Tap(v5) / Gas Range
Frigidaire TGF355BHWC Tap(v6) / Gas Range
Tappan TGF355BHWF Tappan/gas Range
Frigidaire TGF355BXDA Tap(v1) / Gas Range
Frigidaire TGF355BXWA Tap(v2) / Gas Range
Frigidaire TGF356BCDA Tap(v1) / Gas Range
Frigidaire TGF356BCDB Tap(v1) / Gas Range
Frigidaire TGF356BCDC Tap(v1) / Gas Range
Frigidaire TGF356BCDD Tap(v2) / Gas Range
Frigidaire TGF356BCDE Tap(v1) / Gas Range
Frigidaire TGF356BCWA Tap(v2) / Gas Range
Frigidaire TGF356BCWB Tap(v2) / Gas Range
Frigidaire TGF356BCWC Tap(v3) / Gas Range
Frigidaire TGF356BCWD Tap(v4) / Gas Range
Frigidaire TGF356BCWE Tap(v2) / Gas Range
Frigidaire TGF356CCSA Tap(v0) / Gas Range
Frigidaire TGF356CCSC Tap(v0) / Gas Range
Frigidaire TGF356CCSD Tap(v0) / Gas Range
Frigidaire TGF357BCDA Tap(v1) / Gas Range
Frigidaire TGF357BCDC Tap(v1) / Gas Range
Frigidaire TGF357BCDD Tap(v2) / Gas Range
Frigidaire TGF357BCDE Tap(v1) / Gas Range
Frigidaire TGF357BCWA Tap(v2) / Gas Range
Frigidaire TGF357BCWC Tap(v3) / Gas Range
Frigidaire TGF357BCWD Tap(v4) / Gas Range
Frigidaire TGF357BCWE Tap(v2) / Gas Range
Frigidaire TGF357CCSA Tap(v1) / Gas Range
Frigidaire TGF357CCSB Tap(v1) / Gas Range
Frigidaire TGF357CCSC Tap(v1) / Gas Range
Frigidaire TGF357CCSD Tap(v2) / Gas Range
Frigidaire TGF357CCSE Tap(v1) / Gas Range
Frigidaire TGF357CCSF Tap(v3) / Gas Range
Frigidaire TGF357CCSG Tap(v0) / Gas Range
Frigidaire TGF357CCTA Tap(v2) / Gas Range
Frigidaire TGF357CCTB Tap(v2) / Gas Range
  #2 (permalink)
Old 07-02-2009, 12:15 AM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Arrow Check sensor first!
That is the most common cause of an F1 error message but on some controls that same message can be displayed by a problem in the oven temperature sensor (see the following links). That sensor should be tested before replacing the electronic control just in case.
LINK > Tappan TGF336AWD Oven Temp. Sensor
LINK > How do I check an oven temperature sensor?
LINK > Tappan TGF336AWD Electronic Control
That would depend on how handy that average person was. Most reasonably handy homeowners should be able to replace a range's electronic control if necessary.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan Clock Replacement pfd225@roadrunner.com Oven Repair (including Ranges and Cooktops) 5 06-22-2009 10:47 PM
Tappan gas range Debra H Dryer Repair 0 03-10-2009 07:17 AM
Tappan gas range zakyak Oven Repair (including Ranges and Cooktops) 3 02-05-2009 05:40 PM
Replacing Burned Out Light - Tappan Spacesaver Microwave DLBrown Oven Repair (including Ranges and Cooktops) 0 12-13-2008 10:35 AM
Replacing Clock in Jenn Air Range Rosemarie Oven Repair (including Ranges and Cooktops) 0 06-10-2008 08:37 AM
