Discuss
Oven Ignition WOOF!
 in
About 1/2 the time, when starting the oven, there is quite a delay before it lights, and then WOOF, as
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Ignition WOOF!
  #1 (permalink)
Old 12-24-2011, 06:53 AM
Junior Member
pvanv is on a distinguished road
Question Oven Ignition WOOF!
Model Number: FGF355AWE   Brand: Frigidaire   Age: 5 - 10 years
About 1/2 the time, when starting the oven, there is quite a delay before it lights, and then WOOF, as though the ignitor didn't come on soon enough. No explosion that shakes the kitchen, but definitely not right. Certainly scares you the first time it happens. After it is running, it seems to work fine. Controls seem normal. Range works fine. Could this be a failing ignitor, or is it likely some sort of vent problem, control issue, or something else?
Related Models
Frigidaire FGF355AWE Frigidaire/gas Range
Frigidaire FGF355AWG Frigidaire/gas Range
Frigidaire FGF355AWH Frigidaire/gas Range
Frigidaire FGF355BXAWA Frigidaire/gas Range
Frigidaire FGF355CGBA Frg(v1) / Gas Range
Frigidaire FGF355CGBB Frg(v2) / Gas Range
Frigidaire FGF355CGBC Frg(v1) / Gas Range
Frigidaire FGF355CGBD Frg(v2) / Gas Range
Frigidaire FGF355CGBE Frigidaire/gas Range
Frigidaire FGF355CGBF Frigidaire/gas Range
Frigidaire FGF355CGBG Frigidaire/gas Range
Frigidaire FGF355CGSA Frg(v3) / Gas Range
Frigidaire FGF355CGSB Frg(v4) / Gas Range
Frigidaire FGF355CGSC Frg(v3) / Gas Range
Frigidaire FGF355CGSD Frg(v4) / Gas Range
Frigidaire FGF355CGSE Frigidaire/gas Range
Frigidaire FGF355CGSF Frigidaire/gas Range
Frigidaire FGF355CGSG Frigidaire/gas Range
Frigidaire FGF355CGTF Frigidaire/gas Range
Frigidaire FGF355CGTG Frigidaire/gas Range
Frigidaire FGF355DSA Frigidaire/gas Range
Frigidaire FGF355DSB Frigidaire/range
Frigidaire FGF355DSD Frigidaire/range
Frigidaire FGF355DUA Frigidaire/gas Range
Frigidaire FGF355DUB Frigidaire/range
Frigidaire FGF355DWA Frigidaire/gas Range
Frigidaire FGF355DWB Frigidaire/range
Frigidaire FGF355DWD Frigidaire/range
Frigidaire FGF355FSA Frigidaire/range
Frigidaire FGF355FSB Frigidaire/range
Frigidaire FGF355FSD Frigidaire/gas Range
Frigidaire FGF355FSE Frigidaire/range
Frigidaire FGF355FWA Frigidaire/range
Frigidaire FGF355FWB Frigidaire/range
Frigidaire FGF355FWD Frigidaire/gas Range
Frigidaire FGF355FWE Frigidaire/range
Frigidaire FGF355GWA GAS RANGE
Frigidaire FGF355GWB GAS RANGE
Frigidaire FGF355GWC GAS RANGE
Frigidaire FGF355GWD GAS RANGE
Frigidaire FGF355GWE GAS RANGE
Frigidaire FGF356MXAWA Frigidaire/gas Range
Frigidaire FGF356MXAWB Frigidaire/gas Range
Frigidaire FGF356MXAWD Frigidaire/gas Range
Frigidaire FGF358CGSA Frg(v1) / Gas Range
Frigidaire FGF358CGSB Frg(v2) / Gas Range
Frigidaire FGF358CGSC Frg(v0) / Gas Range
Frigidaire FGF358CGSD Frg(v1) / Gas Range
Frigidaire FGF358CGSE Frg(v2) / Gas Range
Frigidaire FGF363BABA Frg(v4) / Gas Range
Frigidaire FGF363BADA Frg(v2) / Gas Range
Frigidaire FGF363BAWA Frg(v1) / Gas Range
Frigidaire FGF363CASA Frg(v3) / Gas Range
Frigidaire FGF363MXASA Frigidaire/gas Range
Frigidaire FGF363MXASB Frigidaire/gas Range
Frigidaire FGF363MXASE Frigidaire/gas Range
Frigidaire FGF363MXCCA Frigidaire/gas Range
Frigidaire FGF363MXCCB Frigidaire/gas Range
Frigidaire FGF364KCA GAS RANGE
Frigidaire FGF364KCB GAS RANGE
Frigidaire FGF364KCC GAS RANGE
Frigidaire FGF364KCD GAS RANGE
Frigidaire FGF364KCF GAS RANGE
Frigidaire FGF364KCG GAS RANGE
Frigidaire FGF364KSA GAS RANGE
Frigidaire FGF365AQA Frigidaire/range
Frigidaire FGF365ASA Frigidaire/range
Frigidaire FGF365AUA Frigidaire/range
Frigidaire FGF365AWA Frigidaire/range
Frigidaire FGF365DQA Frigidaire/gas Range
Frigidaire FGF365DQC Frigidaire/range
Frigidaire FGF365DSA Frigidaire/gas Range
Frigidaire FGF365DSC Frigidaire/range
Frigidaire FGF365DUA Frigidaire/gas Range
Frigidaire FGF365DUC Frigidaire/range
Frigidaire FGF365DWA Frigidaire/gas Range
Frigidaire FGF365DWC Frigidaire/range
Frigidaire FGF365MXFCA Frigidaire/gas Range
Frigidaire FGF366ASA Frigidaire/gas Range
Frigidaire FGF366ASB Frigidaire/gas Range
Frigidaire FGF366ASD Frigidaire/range
Frigidaire FGF366ASE Frigidaire/gas Range
Frigidaire FGF366AUA Frigidaire/gas Range
Frigidaire FGF366AWA Frigidaire/gas Range
Frigidaire FGF366BCA Frigidaire/gas Range
Frigidaire FGF366BCB Frigidaire/gas Range
Frigidaire FGF366BCC Frigidaire/gas Range
Frigidaire FGF366CBB Frigidaire/gas Range
Frigidaire FGF366CBC Frigidaire/gas Range
Frigidaire FGF366CBD Frigidaire/gas Range
Frigidaire FGF366CBE Frigidaire/gas Range
Frigidaire FGF366CBF Frigidaire/gas Range
Frigidaire FGF366CCA Frigidaire/gas Range
Frigidaire FGF366CCB Frigidaire/gas Range
Frigidaire FGF366CCC Frigidaire/gas Range
Frigidaire FGF366CCD Frigidaire/gas Range
Frigidaire FGF366CQB Frigidaire/gas Range
Frigidaire FGF366CQC Frigidaire/gas Range
Frigidaire FGF366CQD Frigidaire/gas Range
Frigidaire FGF366CQE Frigidaire/gas Range
Frigidaire FGF366CQF Frigidaire/gas Range
Frigidaire FGF366CSB Frigidaire/gas Range
Frigidaire FGF366CSC Frigidaire/gas Range
Frigidaire FGF366CSD Frigidaire/gas Range
Frigidaire FGF366CSE Frigidaire/gas Range
Frigidaire FGF366CSF Frigidaire/gas Range
Frigidaire FGF366DBA Frigidaire/gas Range
Frigidaire FGF366DBB Frigidaire/range
Frigidaire FGF366DBD Frigidaire/range
Frigidaire FGF366DCA Frigidaire/gas Range
Frigidaire FGF366DCB Frigidaire/gas Range
Frigidaire FGF366DCC Frigidaire/range
Frigidaire FGF366DCD Frigidaire/range
Frigidaire FGF366DCE Frigidaire/range
Frigidaire FGF366DCF Frigidaire/range
Frigidaire FGF366DCG Frigidaire/range
Frigidaire FGF366DQA Frigidaire/gas Range
Frigidaire FGF366DQB Frigidaire/range
Frigidaire FGF366DQD Frigidaire/range
Frigidaire FGF366DSA Frigidaire/gas Range
  #2 (permalink)
Old 12-27-2011, 06:06 AM
Junior Member
Default
If I understand right, this isn't spark ignition, but a hot electric heater element ignition. Is it reasonable for that to be intermittent?
  #3 (permalink)
Old 12-27-2011, 06:29 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Could be a week ignitor.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #4 (permalink)
Old 12-28-2011, 03:31 AM
Junior Member
Default
Quote:
Can I diagnose that? Maybe a resistance check, or an IR thermometer reading? I hate to guess, and just swap parts that "might" be the problem.
  #5 (permalink)
Old 01-01-2012, 05:28 AM
Junior Member
Question
Is there a way to test for a weak ignitor without just guessing and swapping a part willy-nilly?
  #6 (permalink)
Old 01-02-2012, 02:24 PM
Junior Member
Default
Quote:
There MUST be a way to test the ignitor, right?
  #7 (permalink)
Old 01-02-2012, 02:25 PM
Senior Expert
APP Volunteer
Default
I use a clamp on amp meter to test a ignitor. The gas valve has printed on the side how many amps the ignitor must draw to open the valve.
__________________
  #8 (permalink)
Old 01-02-2012, 02:43 PM
Senior Expert
APP Volunteer
Default
Here are a few pages on just how it all works.
http://appliancejunk.com/forums/inde...=view;down=415
__________________
  #9 (permalink)
Old 01-03-2012, 05:28 AM
Junior Member
Default
Ah, I see... So... high resistance of either the ignitor or the safety valve could prevent the safety valve from opening reliably. Likewise, it's possible that dirt or debris could be restricting gas flow in the burner. Will check and report back. Many thanks, AJ!
  #10 (permalink)
Old 01-13-2012, 05:12 AM
Junior Member
Default
After running the self-clean function, the oven is now working properly. Might have been some debris, which burned off during the high temperatures of the self-cleaning, that was preventing proper ignition.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Ignition wofam Oven Repair (including Ranges and Cooktops) 1 10-04-2011 08:21 AM
No oven ignition RobertT Oven Repair (including Ranges and Cooktops) 0 12-27-2010 03:43 PM
No oven Ignition transpo Oven Repair (including Ranges and Cooktops) 0 05-25-2010 09:14 AM
Oven ignition richard vessa Oven Repair (including Ranges and Cooktops) 0 11-20-2009 06:54 AM
slow oven ignition ArtF Oven Repair (including Ranges and Cooktops) 0 12-09-2008 01:37 PM
