Discuss
Whirpool oven Front Panel
 in
When I closed the door this time for it got closed with good force (my mistake). It caused the hook
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirpool oven Front Panel
  #1 (permalink)
Old 07-01-2009, 10:31 AM
Junior Member
applhelp is on a distinguished road
Default Whirpool oven Front Panel
Brand: Whirlpool   Age: Less than 1 year
When I closed the door this time for it got closed with good force (my mistake). It caused the hook that closes the door to snap and the oven light connection to get messed up. Due to this the hook is totally loose and the oven light does not go off. It gets pretty heated (light). I had to shut the main switch for oven. How to do I repair the hook and make sure the light connection which is inside the front panel is properly repaired. I removed small screws in front that I could see but I could not open the panel etc to go inside the top portion where I could see the wires etc from outside. How do repair it? How do I remove the top portion so that I can go inside where the displays are? Do I need to take the whole oven out? I would prefer not but in that case, how do I take it out? I would appreciate if someone responds preferably with help using the oven diagrams etc. But any help is appreciated.
Thanks,
Ads By Google
  #2 (permalink)
Old 07-01-2009, 07:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The complete model number of the oven might help others to help you.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Front Load washer codes F & H Dawn Griffin Washer Repair 3 07-16-2009 01:57 PM
whirpool electric double oven panel doesn't work betty23 Oven Repair (including Ranges and Cooktops) 3 03-20-2009 03:33 PM
Whirpool Duet Gas Dryer control panel problems moeman12 Dryer Repair 3 02-28-2009 10:29 PM
Replace GE oven door front panel sandman75 Oven Repair (including Ranges and Cooktops) 0 12-27-2008 04:22 PM
Whirpool retainer access panel kedowl Dishwasher Repair 1 12-14-2007 01:51 PM
