rollsfixer
#1 Posted : Wednesday, July 1, 2009 4:40:19 AM(UTC)
rollsfixer
Oven will not heat.
Heating element checks OK
Oven Control Switch had burned contact, and I replaced the switch. No help.
Voltage across the two wires to the heating element = 0 when oven should be heating.
Voltage from one heating element wire to ground = 115 when oven should be heating
voltage from other wire to ground = 0 at all times
light on temperature control is on whenever set temperature is more than actual temperature (indicating heating element is being supplied power) even when the function select switch is off. Normally it should light only when the oven select switch is set to bake or broil. This has been a problem for awhile, but since it is only an indicating light, and it had not been accompanied by any other problem, the malfunctioning light has been ignored until now. It could be related to the current problem, or possibly unrelated.
Broiler element heats fine, and it will cycle on and off according to temperature setting of temperature dial. (Yes, I know for broiling the dial should be turned to high end of the temperature select range, which is marked "broil.)
All other range functions work properly.
I believe power supply board is OK since appropriate power is being supplied to all other functions.
I suspect "Circuit Board" because I think every other thing has been eliminated. However, it is a little pricy at $170, and I would like another opinion before I spend that money.
Thanks for any assistance, advice, etc. Bill V.
Dan O.
#2 Posted : Wednesday, July 1, 2009 1:11:17 PM(UTC)
Dan O.
Than you are not getting one leg of the power supply to the element. Someone would need to trace its route on the appliance's wiring diagram to see what components are in its path that might be responsible for power interruptions.
That may very well be a possibility unfortunately I do not have access to a wiring diagram for your model to say for certain.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
