Discuss
Broiler element- feed wires lost insulation
 in
Hi, THis is my first posting. I just ordered a replacement top broiler element for our old Tappan oven. The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broiler element- feed wires lost insulation
  #1 (permalink)
Old 07-01-2009, 06:29 AM
shamrocksdoc shamrocksdoc is offline
Junior Member
shamrocksdoc is on a distinguished road
Default Broiler element- feed wires lost insulation
Brand: Tappan   Age: More than 10 years
I just ordered a replacement top broiler element for our old Tappan oven. The old one had a burned out section where the element was bent forward in the oven.
When I unscrewed the plate that holds the element to the back wall of the oven, I noticed that the wires leading to it,from behind in the fiberglass insulation, were missing some insulation for a few inches. They were dry and brittle.
Is there a way to coat or insulate these wires before replacing the element? Obvioiusly shrink tubing would not work in a hot environment?
THanks,
Dave
(new part # is AP2115628)
  #2 (permalink)
Old 07-01-2009, 03:15 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool Poor wiring
No. The wires could either be cut back to a where a good section of wire is and then attached to the element or if that would not leave enough wire, either a new piece of wire attached to a good section of the old or a whole wire installed in place of the original.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 07-01-2009, 05:44 PM
Junior Member
Default
Dan,
THanks for the reply.
If I need to splice some in, do I need to buy a special high temp resistant wire to do this, and if so where would I get it?
  #4 (permalink)
Old 07-02-2009, 12:33 AM
Senior Expert
APP Volunteer
Exclamation Range wire
Yes. It is usually rated 150°C and for an oven element would usually need to be 12 Ga.
Most appliance parts suppliers will sell it by the foot if you have such a store locally. The appliance manufacturers often have it available in 24' (or longer) rolls but I don't know Frigidaire's part number for it.
JFYI
Dan O.
=D~~~~~~
  #5 (permalink)
Old 07-02-2009, 04:25 AM
Junior Member
Default
I will try and find such a place. I live in a semi-rural area so will start at appliance repair places.
Thanks for the help,
Dave
  #6 (permalink)
Old 07-03-2009, 12:11 PM
Senior Expert
APP Volunteer
Lightbulb Brittle wire
One should be able to make up a whole replacement wire for you if you provide a sample of the original to duplicate.
Good luck!
Dan O.
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Broiler Element tzurita Oven Repair (including Ranges and Cooktops) 2 04-28-2009 07:10 AM
Broiler Element vs. Bake Element sblank3 Oven Repair (including Ranges and Cooktops) 6 02-18-2009 08:16 AM
How to check the wires on bake and heating element in oven Ladybugg Oven Repair (including Ranges and Cooktops) 0 12-28-2008 06:46 AM
Broiler element jaethri Oven Repair (including Ranges and Cooktops) 1 07-10-2008 09:35 PM
Broiler Element david323 Oven Repair (including Ranges and Cooktops) 1 11-23-2007 12:30 PM
