| » Feature not available |
Model Number: whirlpool gfe461lvbo Brand: Whirlpool Age: 1 - 5 years
When I try to bake I get this "feature not available" and does not work, not sure what to check, don't show any error code, is there a service manual available for this range.
Thanks for any help you can give. freddie Ads By Google Related Models |
I looked at the tech sheet and did not see anything about it.
There is a diagnostic mode in the tech sheet you can try.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
Thanks AJ for the quick reply, I read tech sheet and was able to enter diagnostic mode, had runaway temp error and temp sensor , I reset errors and oven came back on, will see if it comes back. will report back so maybe help someone else with same problem.
thanks again for the information. freddie |
Your welcome, let me know.
__________________
Thanks again AJ we used it this morning, and seems to work ok other than wife seems to think its not getting to the temp she had set, I will check later with thermometer and ohm meter sensor, any insights as to what would do this, temp sensor or control board. Is there a manual that shows how to remove sensor and control board?
thanks again for all your help long time sense I have worked on appliance's. freddie |
| Display Modes | |
| Error Message: FEATURE NOT AVAILABLE | tonimallen | Oven Repair (including Ranges and Cooktops) | 0 | 04-04-2011 02:40 PM |
| Self Cleaning Feature | genej | Oven Repair (including Ranges and Cooktops) | 3 | 11-10-2010 05:51 PM |
| Self cleaning feature | Dave6000 | Oven Repair (including Ranges and Cooktops) | 0 | 03-13-2010 02:21 PM |
| Sears Feature 5 | RLyczkowski | Microwave Repair | 0 | 06-17-2009 07:07 AM |
