| » Substitute part for Wire Harness |
Model Number: KEDS100SCB0 Brand: Kitchen Aid Age: More than 10 years
Serial Number: F71503537
Part discontinued in 1996. Is there a substitute for part #3147976. Surface Unit Harness?? Related Models |
What was the original problem? Why do you think the whole harness has to be replaced?
__________________
Professional appliance repair in Orange County, California. |
Wire insulation has deteriorated on some parts of the harness and the contacts with the burner element have deteriorated so that the element does not make contact. I could replace the contacts and get it to work OK, but that the insulation is black and fragile in areas worries me. I found a universal receptacle kit part #3374 that replaced only the terminal receptacles of the wire harness and replaced all the charred and damaged portions. Problem solved. Everything works great again.
Quote:
The element receptacle (see the following link) comes with short wire leads attached to the element contacts that can be connected to the original wiring. LINK > Surface Element Receptacle Kit If however the original receptacle is needing replacement due to burning/melting, the tips of the element should be inspected before just replacing the receptacle. See the following link: LINK > The surface element on my range will only work if I jiggle it. Can you tell me what's wrong? If needed, these are the element for your model: LINK > Surface Element, Small LINK > Surface Element, Large JFYI Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
| Display Modes | |
| Gas Re-Igniter Substitute Part | richard111 | Oven Repair (including Ranges and Cooktops) | 1 | 04-13-2009 07:23 PM |
| Substitute magnetron | tom12345 | Microwave Repair | 7 | 03-16-2009 06:29 PM |
| Switch Wire Harness | alanbarry | Oven Repair (including Ranges and Cooktops) | 0 | 02-25-2009 03:18 PM |
| Wire harness broken in freezer door | jdogger | Refrigerator & Freezer Repair | 5 | 04-08-2008 04:14 PM |
| Terminal Block / Wire Harness installation | mmol_75 | Dryer Repair | 1 | 04-01-2008 04:30 PM |
