My oven control panel shows codes E6 and F2. Sometimes it will work and mostly not. What do I need and how do I fix it?
Open the control panel. Remove the control panel ribbon cable from the control board slot and clean the connector using a pencil eraser. Check the tracks in the ribbon cable for a hairline cracks. A magnifying glass helps here. Clean the connector on the control board using an isopropyl alcohol. Make sure it's evaporated before reconnecting. If it did not help then replace the control panel. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBD245PDB8 | AppliancePartsPros.comGene.
