cren722
#1 Posted : Tuesday, December 20, 2011 1:14:07 PM(UTC)
cren722
Oven wasn't working, replaced elements,still not working, help!
#2 Posted : Wednesday, December 21, 2011 4:07:23 AM(UTC)
Here are the parts
Replacement parts for FRIGIDAIRE FEF365ASK Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/p...pringfield/316255311.pdf
Does the unit indicate that it is ready.
if yes then it may be the oven sensor (the oven thinks it is already at set temperature so does not heat).
Here is a good link about it, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
Open the back of the unit and check the wiring.
If the wiring and sensor are OK then odds are that the control board is toast.
I am assuming that the stove top elements run OK.
cren722
#3 Posted : Wednesday, December 21, 2011 8:43:23 AM(UTC)
cren722
Yes, the top of the range works great! Took back off, both bake & broil terminals r hot. How can i check the temperature sensor? Thanx!
#4 Posted : Thursday, December 22, 2011 1:18:04 AM(UTC)
[COLOR="DarkRed"]How can i check the temperature sensor? [/COLOR]
take a look at the link.
You will need a meter.
This would have saved you the cost of the elements as you could have checked them for resistance and found them OK.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
by gplundell@msn.com 4/21/2015 3:33:43 PM(UTC)
by paulgbernard 2/14/2015 3:50:00 PM(UTC)
Oven NOT heating up at all (Oven Repair (including Ranges and Cooktops))
by bkevans88 10/31/2014 6:14:02 PM(UTC)
Oven not heating up right. (Oven Repair (including Ranges and Cooktops))
by clueless78 10/17/2014 2:49:30 PM(UTC)
Oven not heating up after self cleaning (Oven Repair (including Ranges and Cooktops))
by JD40 3/18/2014 6:25:03 PM(UTC)
Oven not heating up (Microwave Repair)
by coldoc89 5/9/2013 7:06:35 PM(UTC)
oven not heating up (Oven Repair (including Ranges and Cooktops))
by vwforonda 8/21/2012 5:54:27 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
convection oven not heating up to correct temperature (Oven Repair (including Ranges and Cooktops))
by cecelo 1/17/2012 6:57:16 AM(UTC)
oven not heating up to temperature (Oven Repair (including Ranges and Cooktops))
by buhr 9/12/2011 11:43:11 AM(UTC)
by doette-56 3/6/2011 4:37:05 PM(UTC)
by rpeters23 2/22/2011 5:17:07 PM(UTC)
