Discuss
Maytag Gas Wall Oven Will Not Heat
 in
Help me! I turned on my oven and no heat. The ignitor glows red hot but no gas flames. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Gas Wall Oven Will Not Heat
  #1 (permalink)
Old 06-30-2009, 07:29 AM
jpecobird1 jpecobird1 is offline
Junior Member
jpecobird1 is on a distinguished road
Unhappy Maytag Gas Wall Oven Will Not Heat
Model Number: CWG4020   Brand: Maytag   Age: More than 10 years
Help me! I turned on my oven and no heat. The ignitor glows red hot but no gas flames. I am at a loss - cannot afford to replace it right now and really don't want to rob Peter to pay a service tech if I can avoid it. I am very handy around the house with electric and plumbing so hopefully if you can help me diagnose this, I can fix it myself. The only problems I have had are the thermostat had to be replaced in 2001 and have replaced the seals - otherwise no problems with this oven.
Related Models
Maytag CWG4020AAB Walloven - Cont Clean Gas
Maytag CWG4020BAB Walloven - Cont Clean Gas
Maytag CWG4100AAB Walloven - Std Gas
Maytag CWG450 Walloven - Std Gas
Maytag CWG451 Walloven - Cont Clean Gas
Maytag CWG4510AAB Walloven - Cont Clean Gas
Maytag CWG4510BAB Walloven - Cont Clean Gas
Maytag CWG4600AAB Walloven - Std Gas
Admiral CWGA200AAB Walloven - Cont Clean Gas
Admiral CWGA800AAB Walloven - S/c Gas
Admiral CWGA800AAE Walloven - S/c Gas
Whirlpool CWI1701W0
Whirlpool CWI1701W1
Whirlpool CWI2101W0
Whirlpool CWI2101W1
Frigidaire CWS3600AS0 Fs Washer - Frig/best Buy
Frigidaire CWS3600AS1 Frigidaire/washer
Frigidaire CWS445RGS0 Gib(v0) / Free Standing Washer
Frigidaire CWS445RGS1 Gib(v0) / Free Standing Washer
Maytag CX8670RB Surface Unit - Ele
Maytag CX8670RV Surface Unit - Ele
Maytag CX8670TB Surface Unit - Ele
Maytag CX8670TV Surface Unit - Ele
Maytag CX9875VVV Walloven - S/c Ele
Maytag CX9875VYV Walloven - S/c Ele
Maytag CX9875XYB Walloven - S/c Ele
Whirlpool CXA1300W0
Whirlpool CXA1300W1
Whirlpool CXA1300W2
Whirlpool CXA1300W3
Whirlpool CXA1300W4
Whirlpool CXA1300W5
Whirlpool CXA1300W7
Whirlpool CXA1300W8
Whirlpool CXA1300W9
Whirlpool CXA1700W0
Whirlpool CXA1700W1
Whirlpool CXA1700W3
Whirlpool CXA1700W4
Whirlpool CXA1700W5
Whirlpool CXA1750W0
Whirlpool CXA1750W1
Whirlpool CXA2000W0
Whirlpool CXA2000W1
Whirlpool CXA2000W3
Whirlpool CXA2000W4
Whirlpool CXA2000W5
Whirlpool CXA2500W0
Whirlpool CXA2500W1
Whirlpool CXA2500W3
Whirlpool CXA2500W4
Whirlpool CXA2500W5
Whirlpool CXA3500W0
Whirlpool CXA3500W3
Whirlpool CXA3500W4
Whirlpool CXA3510W0
Whirlpool CXB1400W0
Whirlpool CXB1400W1
Whirlpool CXE1700W0
Whirlpool CXE1700W1
Whirlpool CXE1700W2
Whirlpool CXE1700W3
Whirlpool CXE2100W0
Whirlpool CXE2100W2
Whirlpool CXE2100W3
Whirlpool CXE2100W4
Whirlpool CXI1701W0
Whirlpool CXI1701W1
Whirlpool CXI1701W2
Whirlpool CXI1701W3
Whirlpool CXI1701W4
Whirlpool CXI2101W0
Whirlpool CXI2101W2
Whirlpool CXI2101W3
Whirlpool CXI2101W4
Whirlpool CXI2101W5
Whirlpool CXTK3E
International CYE1000AYW Dryer - Ele
International CYE2000AKW Dryer - Ele
Magic Chef CYE2000AYA Dryer - Ele
Magic Chef CYE2000AYW Dryer - Ele
Magic Chef CYE2000AZW Dryer - Ele
International CYE3004AGW Dryer - Ele
International CYE3004AKW Dryer - Ele
Magic Chef CYE3004AYW Dryer - Ele
Magic Chef CYE3004AZW Dryer - Ele
International CYE3005AGW Dryer - Ele
Magic Chef CYE3005AKW Dryer - Ele
Magic Chef CYE3005AYW Dryer - Ele
Magic Chef CYE3005AZW Dryer - Ele
International CYE4000AGW Dryer - Ele
Magic Chef CYE4000AYA Dryer - Ele
Magic Chef CYE4000AYS Dryer - Ele
Magic Chef CYE4000AYW Dryer - Ele
Magic Chef CYE4000AZS Dryer - Ele
Magic Chef CYE4000AZW Dryer - Ele
International CYG1000AWW Dryer - Gas
Magic Chef CYG1004AWW Dryer - Gas
Magic Chef CYG1005AWW Dryer - Gas
Magic Chef CYG2000AWA Dryer - Gas
Magic Chef CYG2000AWW Dryer - Gas
Magic Chef CYG3004AWW Dryer - Gas
Magic Chef CYG3005AWW Dryer - Gas
Magic Chef CYG4000AWA Dryer - Gas
Magic Chef CYG4000AWS Dryer - Gas
Magic Chef CYG4000AWW Dryer - Gas
Hardwick D-150 Range - F/s Std Ele
Hardwick D-170 Range - F/s Std Ele
Hardwick D-445 Surface Unit - Ele
Hardwick D-456 Surface Unit - Ele
Hardwick D-950 Range - F/s Std Ele
Amana D1150.000 Mwave - Family Size (60 Hz)
Jenn-Air D120 Range - D/i Std Ddraft Ele
Amana D1200 Mwave - Family Size (60 Hz)
Amana D1250 Mwave - Family Size (60 Hz)
Amana D1270.000 Mwave - Family Size (60 Hz)
Amana D1280.000 Mwave - Family Size (60 Hz)
Amana D13 Freezer - Vertical
Amana D13A Freezer - Vertical
Amana D13C Freezer - Vertical
  #2 (permalink)
Old 07-01-2009, 08:46 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Unhappy Ignitor glowing
That model number is incomplete. Did you get it right off the appliance's model and serial number identification tag?
You can find tips for locating the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
No gas getting to the oven burner could be caused by a defective ignitor or a problem in the oven gas valve. And yes, an ignitor can glow and still be defective. The only way to determine which (besides trial and error) is to test the amperage draw on the ignitor circuit as described at the following link.
LINK > Understanding Gas Oven Ignition Systems
The ignitor most likely used on your model should usually draw 3.2 - 3.6 amps. If it drew above or below that it would likely be defective and need to be replaced. If it was within those tolerances, the gas valve would be suspect.
LINK > Maytag CWG4020AAB Oven Ignitor
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1982 Gas Wall oven will not heat trikerdave Oven Repair (including Ranges and Cooktops) 1 04-22-2009 02:15 PM
Maytag Wall Oven Control Panel davechaney Oven Repair (including Ranges and Cooktops) 0 04-15-2009 04:22 PM
Jen Air electric wall oven wont heat zekec Oven Repair (including Ranges and Cooktops) 0 03-27-2009 11:29 AM
Wall Oven, one cook setting won't heat deshawood Oven Repair (including Ranges and Cooktops) 7 01-17-2009 05:32 PM
Wall Oven fluctuating heat chuck999 Oven Repair (including Ranges and Cooktops) 1 10-22-2008 12:11 AM
