Discuss
oven not heating
 in
Oven does not heat. Natural gas oven. Can smell the gas when turn on, and heats somewhat, but doesn't
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven not heating
  #1 (permalink)
Old 06-29-2009, 07:55 PM
cgbates cgbates is offline
Junior Member
cgbates is on a distinguished road
Default oven not heating
Model Number: 31213WAW   Brand: Magic Chef   Age: 1 - 5 years
Oven does not heat. Natural gas oven. Can smell the gas when turn on, and heats somewhat, but doesn't get hot. can see the pilot come on, but doesn't heat properly?? Ideas for problem?
Related Models
Magic Chef 31213WAW Range - F/s Std Gas
Magic Chef 31213XAA Range - F/s Std Gas
Magic Chef 31213XAT
Magic Chef 31213XAW Range - F/s Std Gas
Magic Chef 3121SPA Range - F/s Std Gas
Magic Chef 3121SPL
Magic Chef 3121SPW Range - F/s Std Gas
Magic Chef 3121SRA Range - F/s Std Gas
Magic Chef 3121SRW Range - F/s Std Gas
Magic Chef 3121STA Range - F/s Std Gas
Magic Chef 3121STW Range - F/s Std Gas
Magic Chef 3121WPA Range - F/s Std Gas
Magic Chef 3121WPL
Magic Chef 3121WPV Range - F/s Std Gas
Magic Chef 3121WPW Range - F/s Std Gas
Magic Chef 3121WRA Range - F/s Std Gas
Magic Chef 3121WRV Range - F/s Std Gas
Magic Chef 3121WRW Range - F/s Std Gas
Magic Chef 3121WTA Range - F/s Std Gas
Magic Chef 3121WTV Range - F/s Std Gas
Magic Chef 3121WTW Range - F/s Std Gas
Magic Chef 3121XPA Range - F/s Std Gas
Magic Chef 3121XPL Range - F/s Std Gas
Magic Chef 3121XPS Range - F/s Std Gas
Magic Chef 3121XPW Range - F/s Std Gas
Magic Chef 3121XRA Range - F/s Std Gas
Magic Chef 3121XRA-UX Range - F/s Std Gas
Magic Chef 3121XRA-X Range - F/s Std Gas
Magic Chef 3121XRS Range - F/s Std Gas
Magic Chef 3121XRW Range - F/s Std Gas
Magic Chef 3121XRW-UX Range - F/s Std Gas
Magic Chef 3121XRW-X Range - F/s Std Gas
Magic Chef 3121XTA Range - F/s Std Gas
Magic Chef 3121XTS Range - F/s Std Gas
Magic Chef 3121XTW Range - F/s Std Gas
Magic Chef 3126SRA Range - F/s Std Gas
Magic Chef 3126SRW Range - F/s Std Gas
Magic Chef 3126STA Range - F/s Std Gas
Magic Chef 3126STW Range - F/s Std Gas
Magic Chef 3127STA Range - F/s Std Gas
Magic Chef 3127STW Range - F/s Std Gas
Magic Chef 3127WTA Range - F/s Std Gas
Magic Chef 3127WTV Range - F/s Std Gas
Magic Chef 3127WTW Range - F/s Std Gas
Magic Chef 3127XTA Range - F/s Std Gas
Magic Chef 3127XTW Range - F/s Std Gas
Magic Chef 31311SAA Range - F/s Std Gas
Magic Chef 31311SAW Range - F/s Std Gas
Magic Chef 31311WAA Range - F/s Std Gas
Magic Chef 31311WAW Range - F/s Std Gas
Magic Chef 31315VAM Range - F/s Std Gas
Magic Chef 31315VAV Range - F/s Std Gas
Magic Chef 31315VBM Range - F/s Std Gas
Magic Chef 31315VBV Range - F/s Std Gas
Magic Chef 31315WAM Range - F/s Std Gas
Magic Chef 31315WAV Range - F/s Std Gas
Magic Chef 31315XAA Range - F/s Std Gas
Magic Chef 31315XAW Range - F/s Std Gas
Magic Chef 31315XBA Range - F/s Std Gas
Magic Chef 31315XBW Range - F/s Std Gas
Magic Chef 3141XRA Range - F/s Std Gas
Magic Chef 3141XRW Range - F/s Std Gas
Magic Chef 3141XTA Range - F/s Std Gas
Magic Chef 3141XTW Range - F/s Std Gas
Magic Chef 3147XRA Range - F/s Std Gas
Magic Chef 3147XRA-X Range - F/s Std Gas
Magic Chef 3147XRW Range - F/s Std Gas
Magic Chef 3147XRW-X Range - F/s Std Gas
Magic Chef 3147XTA Range - F/s Std Gas
Magic Chef 3147XTW Range - F/s Std Gas
Magic Chef 3167VTV Range - F/s Std Gas
Magic Chef 3167VTW Range - F/s Std Gas
Magic Chef 3167VUV Range - F/s Std Gas
Magic Chef 3167XRA Range - F/s Std Gas
Magic Chef 3167XRA-X Range - F/s Std Gas
Magic Chef 3167XRW Range - F/s Std Gas
Magic Chef 3167XRW-X Range - F/s Std Gas
Magic Chef 3167XTA Range - F/s Std Gas
Magic Chef 3167XTA-X Range - F/s Std Gas
Magic Chef 3167XTW Range - F/s Std Gas
Magic Chef 3167XTW-X Range - F/s Std Gas
Magic Chef 3167XUA Range - F/s Std Gas
Magic Chef 3167XUA-X Range - F/s Std Gas
Magic Chef 3167XUW Range - F/s Std Gas
Magic Chef 3167XUW-X Range - F/s Std Gas
Magic Chef 3167XYA Range - F/s Std Gas
Magic Chef 3167XYW Range - F/s Std Gas
Magic Chef 3187VRA Range - F/s Std Gas
Magic Chef 3187VRV Range - F/s Std Gas
Magic Chef 3187VTA Range - F/s Std Gas
Magic Chef 3187VTV Range - F/s Std Gas
Magic Chef 3187VUA Range - F/s Std Gas
Magic Chef 3187VUV Range - F/s Std Gas
Magic Chef 3187XRA Range - F/s Std Gas
Magic Chef 3187XRW Range - F/s Std Gas
Magic Chef 3187XTA Range - F/s Std Gas
Magic Chef 3187XTW Range - F/s Std Gas
Magic Chef 3187XUA Range - F/s Std Gas
Magic Chef 3187XUW Range - F/s Std Gas
Magic Chef 31F-8KX-OC Range - F/s Std Gas
Magic Chef 31F6-7K Range - F/s Std Gas
Magic Chef 31FA-1 Range - F/s Std Gas
Magic Chef 31FA-10 Range - F/s Std Gas
Magic Chef 31FA-10-FJ Range - F/s Std Gas
Magic Chef 31FA-10K Range - F/s Std Gas
Magic Chef 31FA-10K-49 Range - F/s Std Gas
Magic Chef 31FA-10K-FJ Range - F/s Std Gas
Magic Chef 31FA-10KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-10KLXS-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-10KXS-ON Range - F/s Std Gas
Magic Chef 31FA-10XS-ON Range - F/s Std Gas
Magic Chef 31FA-11KLX-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-11KW Range - F/s Std Gas
Magic Chef 31FA-11KX-ON Range - F/s Std Gas
Magic Chef 31FA-11KXS-ON Range - F/s Std Gas
Magic Chef 31FA-1K Range - F/s Std Gas
Magic Chef 31FA-1KLXS-ON Range - F/s Cont Clean Gas
Magic Chef 31FA-1KXS-ON Range - F/s Std Gas
Magic Chef 31FA-1XS-EL Range - F/s Std Gas
Magic Chef 31FA-1XS-ON Range - F/s Std Gas
  #2 (permalink)
Old 07-01-2009, 08:58 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Unhappy Ignitor glowing
Your oven uses a 'hot surface' electronic ignition system (see the following link) so it doesn't have a "pilot". You likely see the glow of the oven ignitor.
You can read about how common gas oven ignition systems work and the observations and tests necessary to start diagnosing problems with them at the following link:
LINK > Understanding Gas Oven Ignition Systems
If the gas valve is opening but just that gas isn't being ignited, you likely have a 'weak' oven ignitor. It is likely what is generating the minimal amount of heat you are experiencing but not hot enough to ignite the gas of the burner. And yes, an ignitor can glow and still be defective (see the link above).
LINK > Magic Chef 31213WAW Oven Ignitor
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven door opens when in use causing oven to stop heating puck Oven Repair (including Ranges and Cooktops) 3 03-14-2009 08:25 AM
Bottom heating element in oven not heating Bill Pitts Oven Repair (including Ranges and Cooktops) 1 03-07-2009 07:02 PM
Frigidaire Double Oven/ Top oven not heating dross3491 Oven Repair (including Ranges and Cooktops) 6 12-14-2008 01:33 PM
Oven not heating dlhutch Oven Repair (including Ranges and Cooktops) 1 12-10-2008 06:32 PM
GE Wall Double Oven Top Oven Not Heating ryoung Oven Repair (including Ranges and Cooktops) 0 01-10-2008 09:02 PM
