| tomdice |
12-30-2007 05:41 PM |
Large temperature variance
GE Electric Oven - Model # JRP24C0T1BB - Owner complains that food either burns or not cooked at various times. I tested the oven with a Leeds & Northrup certified electric thermometer and found temperature range variance from +50 to -75, confirming the complaint cause. The oven desired temperature is set and the oven beeps upon reaching the set temp. Thereafter, the set temperature indicator remains constant although the actual oven temperature varies as described. What is the suggested "fix" for this problem?
