Discuss
Amana Oven won't ignite
 in
My stove, Amana model ACS3350AS works fine with the exception of the oven. All the burners and the broiler are
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana Oven won't ignite
  #1 (permalink)
Old 06-29-2009, 07:43 AM
MASOL MASOL is offline
Junior Member
MASOL is on a distinguished road
Default Amana Oven won't ignite
Model Number: #ACS3350AS   Brand: Amana   Age: 5 - 10 years
My stove, Amana model ACS3350AS works fine with the exception of the oven. All the burners and the broiler are OK. The igniter for the lower burner (oven) looks like it glows red hot but the lower burner will never turn on. What is the best way to diagnose this problem?
Related Models
Jenn-Air *A100
Amana /GRILLE Range - S/c S/i Ddraft Gas
Hoover 021 Frigidaire/refrigerator
Hoover 0510
Hoover 0513
Hoover 0515
Hoover 0517-10
Hoover 0517-20
Hoover 0517-30
Hoover 0519
Hoover 0519-10
Hoover 0519-30
Hoover 0519-60 Frigidaire/electric Range
Hoover 0519-70 Frigidaire/electric Range
Hoover 0519-80
Hoover 0610 Frigidaire/freezer
Hoover 0611 White Westinghouse/refrigerator
Hoover 0612 Frigidaire/walloven
Hoover 0613 Frigidaire/freezer
Hoover 0617
Hoover 0617-61 Frigidaire/walloven
Hoover 0617-64 Frigidaire/walloven
Hoover 0620 Frigidaire/walloven
Hoover 0622 Frigidaire/walloven
Hoover 0630 Frigidaire/walloven
Hoover 0632
Hoover 0710 Frigidaire/freezer
Hoover 0750
Whirlpool 0773B10
Whirlpool 0783B10
Hoover 0810
Hoover 0811 Frigidaire/freezer
Hoover 0914 Frigidaire/freezer
Hoover 0914-61 Frigidaire/refrigerator
Hoover 0914-64
Hoover 0916 White Westinghouse/refrigerator
Hoover 0916T
Hoover 0916T-01
Hoover 0920
Admiral 1
Amana 10-2NM Room Air Conditioner
Whirlpool 1005000
Whirlpool 1005200
Whirlpool 1005300
Whirlpool 1005400
Whirlpool 1005500
Amana 1008.000 Mwave - Family Size (60 Hz)
Amana 1009.000 Mwave - Family Size (60 Hz)
Amana 100A-20 Room Air Conditioner
Amana 100A-2M Room Air Conditioner
Amana 100A-2N Room Air Conditioner
Amana 100A-30 Room Air Conditioner
Amana 100A-30H Room Air Conditioner
Amana 100A-356 Room Air Conditioner
Amana 100A-3A Room Air Conditioner
Amana 100A-3HN Room Air Conditioner
Amana 100A-3M Room Air Conditioner
Amana 100A-3N Room Air Conditioner
Amana 100A-3P Room Air Conditioner
Amana 100A-3PH Room Air Conditioner
Amana 100A-3R Room Air Conditioner
Amana 100A-3RH Room Air Conditioner
Amana 100A-556 Room Air Conditioner
Amana 100A-8R Room Air Conditioner
Amana 100B-3A Room Air Conditioner
Amana 100C-20
Amana 100C-20H
Amana 100C-2N Room Air Conditioner
Amana 100C-2N1 Room Air Conditioner
Amana 100C-2P Room Air Conditioner
Amana 100C-2PH Room Air Conditioner
Amana 100C-2R Room Air Conditioner
Amana 100C-2RH Room Air Conditioner
Amana 100C-2RHL Room Air Conditioner
Amana 100C-2RL Room Air Conditioner
Amana 100C-30
Amana 100C-30H
Amana 100C-3N Room Air Conditioner
Amana 100C-3N1 Room Air Conditioner
Amana 100C-3P Room Air Conditioner
Amana 100C-3PH Room Air Conditioner
Amana 100C-3R Room Air Conditioner
Amana 100C-3RH Room Air Conditioner
Amana 100C-3RHL Room Air Conditioner
Amana 100C-3RL Room Air Conditioner
Amana 100C-8P Room Air Conditioner
Amana 100C-8R Room Air Conditioner
Amana 100C-8RH Room Air Conditioner
Amana 100C-8RHL Room Air Conditioner
Amana 100C-8RL Room Air Conditioner
Amana 100D-2HM
Amana 100D-2M
Amana 100D-2MA
Amana 100D-2MB
Amana 100D-356 Room Air Conditioner
Amana 100D-3M
Amana 100D-556 Room Air Conditioner
Amana 100LA-20 Room Air Conditioner
Amana 100LA-2N Room Air Conditioner
Amana 100LC-20
Amana 100LC-2N Room Air Conditioner
Amana 100LC-2P Room Air Conditioner
Amana 100LC-2R Room Air Conditioner
Amana 100LC-2RH Room Air Conditioner
Amana 100LCS-20
Amana 100LCS-2N Room Air Conditioner
Amana 100LCS-2P Room Air Conditioner
Hoover 1010
Amana 1010.000 Mwave - Family Size (60 Hz)
Amana 1011.000 Mwave - Family Size (60 Hz)
Amana 1015.000 Mwave - Family Size (60 Hz)
Amana 1018.000 Mwave - Family Size (60 Hz)
Amana 102.000 Mwave - Family Size (60 Hz)
Amana 102.001 Mwave - Family Size (60 Hz)
Amana 102.002 Mwave - Family Size (60 Hz)
Hoover 1020
Amana 1020.0 Mwave - Family Size (60 Hz)
Amana 1020.000 Mwave - Family Size (60 Hz)
Amana 1021.000 Mwave - Family Size (60 Hz)
Whirlpool 1021B16
  #2 (permalink)
Old 06-29-2009, 01:20 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Arrow Amperage test
Quote:
The igniter glows red hot but the lower burner will [not ignite]. What is the best way to diagnose this problem?
The ignitor glowing but gas not being released into the oven burner could be caused by a problem in the ignitor or the oven gas valve. And yes, an ignitor can glow and still be defective. The only way to diagnose which might be responsible (besides trial and error) is to measure the amperage draw on the ignitor circuit when glowing.
LINK > Amana ACS3350AS Bake Ignitor
LINK > ACS3350AS Oven 'Dual' Gas Valve
The ignitor on your model should draw 3.2 - 3.6 amps when glowing. If it was within those tolerances but the oven valve was not releasing gas into the oven burner, the valve would be suspect and likely need replacing. If the amperage draw was outside those tolerances, the ignitor would likely need to be replaced.
You can read about how common gas oven ignition systems work at the following link:
LINK > Understanding Gas Oven Ignition Systems
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 07-16-2009, 01:27 PM
Junior Member
Default Ignitor was bad
Dan,
Thanks for the diagnoses.
The ignitor read about 2.8 Ohm resistance when hot. After replacement it was in the proper range and worked fine.
Mike
  #4 (permalink)
Old 07-17-2009, 12:35 PM
Junior Member
Default Wrong message it was AMPs
Sorry for the error in the last comment, my mind was elsewhere.
The current on the bad ignitor was 2.8 A when hot and glowing.
  #5 (permalink)
Old 07-17-2009, 02:37 PM
Senior Expert
APP Volunteer
Thumbs up Fixed!
Glad to hear it. Thanks for the follow up.
Dan O.
=D~~~~~~
  #6 (permalink)
Old 07-20-2009, 08:52 AM
Dak Dak is offline
Junior Member
Dak is on a distinguished road
Default Oven takes a very long time to reach temp.
[quote=MASOL;102055]My stove, Amana model ACS3350AS works fine with the exception of the oven. All the burners and the broiler are OK. The igniter for the lower burner (oven) or some other part (s) seem to take the oven a very long time to come up to temp. I am talking about anywhere from 15 minutes to a half hour to reach temp. What is the best way to diagnose this problem ? And can you tell me what parts I need to repair it. Thanks for your time
  #7 (permalink)
Old 07-20-2009, 07:22 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
The problem you described looks very, very similar to the problem described in the previous post by "MASOL". You have to follow the instructions recommended by Dan O.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana oven & broiler quit at the same time- won't ignite js-everett Oven Repair (including Ranges and Cooktops) 1 06-08-2009 01:17 PM
Amana gas dryer won't ignite vgranada Dryer Repair 1 04-09-2009 08:09 AM
Amana gas dryer won't ignite JJim Keenan Dryer Repair 3 01-02-2009 08:48 PM
Oven Won't Ignite zule1980 Oven Repair (including Ranges and Cooktops) 0 11-25-2008 05:12 PM
Oven will not ignite gordo634 Oven Repair (including Ranges and Cooktops) 1 07-22-2008 09:58 AM
