Discuss
Kitchenaid ceramic range
 in
The 2 burners on the left as you look at the range went out at the same time while using
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchenaid ceramic range
  #1 (permalink)
Old 06-29-2009, 06:57 AM
jfuller508 jfuller508 is offline
Junior Member
jfuller508 is on a distinguished road
Default Kitchenaid ceramic range
Model Number: kesc307hbs6   Brand: Kitchen Aid   Age: 5 - 10 years
The 2 burners on the left as you look at the range went out at the same time while using the front burner. The other burners work fine and the oven and all other electronics seem to be fine.
It is a ceramic or glass top. What is the likely problem?
Related Models
Whirlpool KESC307HBS6
Whirlpool KESC307HBS8
Whirlpool KESC307HBT0
Whirlpool KESC307HBT1
Whirlpool KESC307HBT3
Whirlpool KESC307HBT4
Whirlpool KESC307HBT5
Whirlpool KESC307HBT6
Whirlpool KESC307HBT8
Whirlpool KESC307HWH0
Whirlpool KESC307HWH1
Whirlpool KESC307HWH3
Whirlpool KESC307HWH4
Whirlpool KESC307HWH5
Whirlpool KESC307HWH6
Whirlpool KESC307HWH8
Whirlpool KESC307HWW4
Whirlpool KESC307HWW6
Whirlpool KESC307HWW8
Whirlpool KESC308LSS0 30" Slide - in Range Designer Style Convection Oven
Whirlpool KESH307BAL1
Whirlpool KESH307BAL2
Whirlpool KESH307BAL3
Whirlpool KESH307BAL4
Whirlpool KESH307BAL5
Whirlpool KESH307BAL6
Whirlpool KESH307BAL8
Whirlpool KESH307BAL9
Whirlpool KESH307BBL1
Whirlpool KESH307BBL2
Whirlpool KESH307BBL3
Whirlpool KESH307BBL4
Whirlpool KESH307BBL5
Whirlpool KESH307BBL6
Whirlpool KESH307BBL8
Whirlpool KESH307BBL9
Whirlpool KESH307BWH1
Whirlpool KESH307BWH2
Whirlpool KESH307BWH3
Whirlpool KESH307BWH4
Whirlpool KESH307BWH5
Whirlpool KESH307BWH6
Whirlpool KESH307BWH8
Whirlpool KESH307BWH9
Whirlpool KESH307GAL0
Whirlpool KESH307GAL1
Whirlpool KESH307GBL0
Whirlpool KESH307GBL1
Whirlpool KESH307GBS0
Whirlpool KESH307GBS1
Whirlpool KESH307GBT0
Whirlpool KESH307GBT1
Whirlpool KESH307GWH0
Whirlpool KESH307GWH1
Whirlpool KESH307HBL0
Whirlpool KESH307HBL1
Whirlpool KESH307HBL3
Whirlpool KESH307HBL4
Whirlpool KESH307HBL5
Whirlpool KESH307HBL6
Whirlpool KESH307HBS0
Whirlpool KESH307HBS1
Whirlpool KESH307HBS3
Whirlpool KESH307HBS4
Whirlpool KESH307HBS5
Whirlpool KESH307HBS6
Whirlpool KESH307HWH0
Whirlpool KESH307HWH1
Whirlpool KESH307HWH3
Whirlpool KESH307HWH4
Whirlpool KESH307HWH5
Whirlpool KESH307HWH6
Whirlpool KESI901PBL00 30" Slide - in Electric Oven
Whirlpool KESI901PBL01 30" Slide - in Electric Oven
Whirlpool KESI901PBS00 30" Slide - in Electric Oven
Whirlpool KESI901PBS01 30" Slide - in Electric Oven
Whirlpool KESI901PWH00 30" Slide - in Electric Oven
Whirlpool KESI901PWH01 30" Slide - in Electric Oven
Whirlpool KESK901SBL00 30" Slide - in Electric Oven
Whirlpool KESK901SSS00 30" Slide - in Electric Oven
Whirlpool KESK901SWH00 30" Slide - in Electric Oven
Whirlpool KESO140
Whirlpool KESO140S
Whirlpool KESO145
Whirlpool KESO145S
Whirlpool KESO170
Whirlpool KESO170S
Whirlpool KESO175
Whirlpool KESO175S
Whirlpool KESO176S
Whirlpool KESS300BAL0
Whirlpool KESS300BWH0
Whirlpool KESS907SBB00 30" Built - in Electric Oven
Whirlpool KESS907SBL00 30" Built - in Electric Oven
Whirlpool KESS907SSS00 30" Built - in Electric Oven
Whirlpool KESS907SWW00 30" Built - in Electric Oven
Whirlpool KESS908SPB00 30" Slide - in Electric Oven
Whirlpool KESS908SPS00 30" Slide - in Electric Oven
Whirlpool KESS908SPW00 30" Slide - in Electric Oven
Whirlpool KESV908PMT00 30" Slide - in Electric Oven Convection
Whirlpool KESV908PMT01 30" Slide - in Electric Oven Convection
Whirlpool KESV908PSS00 30" Slide - in Electric Oven Convection
Whirlpool KESV908PSS01 30" Slide - in Electric Oven Convection
Amana KET-480 Range - S/c S/i Ddraft Gas
Amana KET-480A Range - S/c S/i Ddraft Gas
Amana KET-480B Range - S/c S/i Ddraft Gas
Amana KET-480C Range - S/c S/i Ddraft Gas
Amana KET570 Surface Unit - Ele
Amana KET590 Surface Unit - Ele
Amana KET595 Surface Unit - Ele
Amana KET700 Surface Unit - Ele
Whirlpool KEWD105HBL0
Whirlpool KEWD105HBL05 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBL06 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBL1
Whirlpool KEWD105HBL3
Whirlpool KEWD105HBL4
Whirlpool KEWD105HBT0
Whirlpool KEWD105HBT05 30" Electric Built - in Warming Drawer
Whirlpool KEWD105HBT06 30" Electric Built - in Warming Drawer
  #2 (permalink)
Old 07-04-2009, 04:05 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question Wiring problem?
Is the range in Canada? Canadian versions of that model are suppose to incorporate a relay which when in clean cuts out the surface elements. If one half of that relay failed, it might produce your symptoms.
Otherwise there doesn't appear to be anything in your range which is designed to affect just those element so either it is just coincidence that either the switch or the element for each happened to fail at the same time or there maybe a problem in the range's wiring common to both those element switches.
Someone might need to look into the switch wiring first then proceed to the switches and then testing the elements if necessary.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace ceramic cooktop on GE JBP65 electric range ClemsonDad Oven Repair (including Ranges and Cooktops) 1 02-16-2009 05:44 PM
Crccked ceramic on range Vmarois2 Oven Repair (including Ranges and Cooktops) 3 11-11-2008 01:30 PM
Replacing element of Maytag Ceramic Top Slide In Range kaliqcda Oven Repair (including Ranges and Cooktops) 0 10-22-2008 06:29 PM
HELP - Replacing range ceramic glass cooktop Paul S Oven Repair (including Ranges and Cooktops) 0 02-28-2008 08:51 AM
Magic Chef drop in range W/ceramic top Phatuesday Oven Repair (including Ranges and Cooktops) 1 02-20-2008 04:04 PM
