| » GE Spectra Oven problem |
Model Number: spectra xl44 Brand: GE Age: 5 - 10 years
My oven takes forever to heat up, and will not maintain temp, and sometimes doesnt even begin to heat up. I have read all prior posts about the ignitor issue.
my only issue that doesnt make sense is that at times the ignitor glows but the oven wont start to warm up, the only way i have figured out to get it warming up is to turn on one of the stove top burners, within 5 secs i hear the gas being released into the oven and the flame starts. Ads By Google Related Models |
Hello reppoc. Based on the information you provided, it sounds like the igniter is weak. Test for 3.2-3.6 volts AC at the gas safety valve with the igniter turned on. If the voltage is there, you have a bad safety valve. If the voltage is low or high, you have a weak igniter and the igniter will need to be replaced. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. How To Check Continuity With Ohmmeter
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| GE Spectra Gas Oven | Randycai | Oven Repair (including Ranges and Cooktops) | 0 | 06-12-2010 12:51 PM |
| GE Spectra Dual Burner problem | willis1000 | Oven Repair (including Ranges and Cooktops) | 1 | 05-26-2009 03:01 PM |
| GE Spectra Range Problem | MitMaster | Oven Repair (including Ranges and Cooktops) | 2 | 01-03-2009 01:52 PM |
| Ge Spectra Oven Problem | dingletobeer | Oven Repair (including Ranges and Cooktops) | 0 | 12-22-2008 10:02 AM |
| GE Spectra oven temp problem | ace o spades | Oven Repair (including Ranges and Cooktops) | 1 | 01-28-2008 11:44 AM |
