| » Magic Chef Oven won't light |
Model Number: 31213xaw Brand: Magic Chef Age: 5 - 10 years
When I try to turn on the oven the igniter gets red hot, but no gas is coming out of the burner. Any ideas or thoughts?
Related Models |
Quote:
You can read about how common gas oven ignition systems work and the observations and tests necessary to start diagnosing problems with them at the following link: LINK > Understanding Gas Oven Ignition Systems The only sure way to isolate which is responsible is to test the amperage draw on the ignitor circuit while glowing. The ignitor used on your model should draw 3.2 to 3.6 amps to be good. Anything above or below and it would likely be defective. If the ignitor was drawing amperage within those tolerances, the gas valve would be assumed to be the problem. Unfortunately few homeowners have an ammeter or amprobe to do such a test. If you wanted to guess, an oven ignitor is the most common (~70-80%) troublemaker in such an ignition system. LINK > Magic Chef 31213XAW Oven Ignitor LINK > 31213XAW Oven Gas Valve JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
| Display Modes | |
| magic chef oven | bgmike8 | Oven Repair (including Ranges and Cooktops) | 1 | 06-01-2009 09:36 PM |
| Magic Chef oven -burner doesn't light | avberviller | Oven Repair (including Ranges and Cooktops) | 8 | 12-05-2008 04:18 PM |
| Magic Chef Oven | lessrob | Oven Repair (including Ranges and Cooktops) | 0 | 10-16-2008 10:11 PM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 01:36 PM |
| Magic Chef gas oven won't light | koohgar | Oven Repair (including Ranges and Cooktops) | 10 | 10-17-2007 03:00 PM |
