:mad: My Thermador rangetop sparks continuously... nonstop, all-the-time. Sparks when the burners are lit and also when all the burners are completely off.
However, I can stop the sparking if I light the Rear/Middle burner (a non-XLO burner). When I have this R/M burner lit, all other burners light normally (including the XLO burners). Once I turn off the R/M burner, the sparking resumes even with other burners operating.
I have not observed any spark shorts, all the ceramics have been cleaned are are not cracked and the spark is strong.
I am scratching my :confused: head. Any ideas from the PartsPros?
Model: Thermador Professional PRSE486GLS Model PRSE486GLS
Originally Posted by: Gene Gene. Thank you for the advice. I believe the switches are behind the control valves. However, I am not sure how to get to them. Do I need to disassemble the front panel? Or can I get to the back of the panel from the top somehow?
You do have to remove the control panel to access the switches. The instructions are attached to the reply. Gene.
