Discuss
Electric wall oven
 in
The oven is heating to about 70 degrees above the set temp. I checked the sensors (it has an upper
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric wall oven
  #1 (permalink)
Old 12-15-2011, 11:58 AM
Junior Member
dwayne40 is on a distinguished road
Default Electric wall oven
Model Number: jjw8230dds   Brand: Jenn-Air   Age: Less than 1 year
The oven is heating to about 70 degrees above the set temp. I checked the sensors (it has an upper and lower oven and both are high) and they measure a resistance of 1070 ohms. This is within range. What else can I check?
Ads By Google
Related Models
Jenn-Air JJW8230DDS Walloven - S/c Ele
Jenn-Air JJW8230DDW Walloven - S/c Ele
Jenn-Air JJW8527AAB Walloven - S/c Ele
Jenn-Air JJW8527AAW Walloven - S/c Ele
Jenn-Air JJW8527BAB Walloven - S/c Ele
Jenn-Air JJW8527BAW Walloven - S/c Ele
Jenn-Air JJW8527CAB Walloven - S/c Ele
Jenn-Air JJW8527CAS Walloven - S/c Ele
Jenn-Air JJW8527CAW Walloven - S/c Ele
Jenn-Air JJW8527DDB Walloven - S/c Ele
Jenn-Air JJW8527DDQ Walloven - S/c Ele
Jenn-Air JJW8527DDS Walloven - S/c Ele
Jenn-Air JJW8527DDW Walloven - S/c Ele
Jenn-Air JJW8530AAB Walloven - S/c Ele
Jenn-Air JJW8530AAW Walloven - S/c Ele
Jenn-Air JJW8530ACB Walloven - S/c Ele
Jenn-Air JJW8530ACW Walloven - S/c Ele
Jenn-Air JJW8530BAB Walloven - S/c Ele
Jenn-Air JJW8530BAW Walloven - S/c Ele
Jenn-Air JJW8530BCB Walloven - S/c Ele
Jenn-Air JJW8530BCW Walloven - S/c Ele
Jenn-Air JJW8530CAB Walloven - S/c Ele
Jenn-Air JJW8530CAS Walloven - S/c Ele
Jenn-Air JJW8530CAW Walloven - S/c Ele
Jenn-Air JJW8530CCB Walloven - S/c Ele
Jenn-Air JJW8530CCW Walloven - S/c Ele
Jenn-Air JJW8530DDB Walloven - S/c Ele
Jenn-Air JJW8530DDQ Walloven - S/c Ele
Jenn-Air JJW8530DDS Walloven - S/c Ele
Jenn-Air JJW8530DDW Walloven - S/c Ele
Jenn-Air JJW8627AAB Walloven - S/c Ele
Jenn-Air JJW8627AAW Walloven - S/c Ele
Jenn-Air JJW8627BAB Walloven - S/c Ele
Jenn-Air JJW8627BAW Walloven - S/c Ele
Jenn-Air JJW8627CAB Walloven - S/c Ele
Jenn-Air JJW8627CAS Walloven - S/c Ele
Jenn-Air JJW8627CAW Walloven - S/c Ele
Jenn-Air JJW8627DDB Walloven - S/c Ele
Jenn-Air JJW8627DDQ Walloven - S/c Ele
Jenn-Air JJW8627DDS Walloven - S/c Ele
Jenn-Air JJW8627DDW Walloven - S/c Ele
Jenn-Air JJW8630AAB Walloven - S/c Ele
Jenn-Air JJW8630AAW Walloven - S/c Ele
Jenn-Air JJW8630BAB Walloven - S/c Ele
Jenn-Air JJW8630BAW Walloven - S/c Ele
Jenn-Air JJW8630CAB Walloven - S/c Ele
Jenn-Air JJW8630CAS Walloven - S/c Ele
Jenn-Air JJW8630CAW Walloven - S/c Ele
Jenn-Air JJW8630DDB Walloven - S/c Ele
Jenn-Air JJW8630DDQ Walloven - S/c Ele
Jenn-Air JJW8630DDS Walloven - S/c Ele
Jenn-Air JJW8630DDW Walloven - S/c Ele
Jenn-Air JJW9130DDB Walloven - S/c Ele
Jenn-Air JJW9130DDS Walloven - S/c Ele
Jenn-Air JJW9130DDW Walloven - S/c Ele
Jenn-Air JJW9230DDB Walloven - S/c Dbl Oven Ele
Jenn-Air JJW9230DDS Walloven - S/c Dbl Oven Ele
Jenn-Air JJW9230DDW Walloven - S/c Dbl Oven Ele
Jenn-Air JJW9430DDB Walloven - S/c Dbl Oven Ele
Jenn-Air JJW9430DDS Walloven - S/c Dbl Oven Ele
Jenn-Air JJW9430DDW Walloven - S/c Dbl Oven Ele
Jenn-Air JJW9527AAB Walloven - S/c Ele
Jenn-Air JJW9527AAQ Walloven - S/c Ele
Jenn-Air JJW9527AAS Walloven - S/c Ele
Jenn-Air JJW9527AAW Walloven - S/c Ele
Jenn-Air JJW9527BAB Walloven - S/c Ele
Jenn-Air JJW9527BAQ Walloven - S/c Ele
Jenn-Air JJW9527BAS Walloven - S/c Ele
Jenn-Air JJW9527BAW Walloven - S/c Ele
Jenn-Air JJW9527CAB Walloven - S/c Ele
Jenn-Air JJW9527CAQ Walloven - S/c Ele
Jenn-Air JJW9527CAS Walloven - S/c Ele
Jenn-Air JJW9527CAW Walloven - S/c Ele
Jenn-Air JJW9527DDB Walloven - S/c Ele
Jenn-Air JJW9527DDS Walloven - S/c Ele
Jenn-Air JJW9527DDW Walloven - S/c Ele
Jenn-Air JJW9530AAB Walloven - S/c Ele
Jenn-Air JJW9530AAQ Walloven - S/c Ele
Jenn-Air JJW9530AAS Walloven - S/c Ele
Jenn-Air JJW9530AAW Walloven - S/c Ele
Jenn-Air JJW9530ACB Walloven - S/c Ele
Jenn-Air JJW9530ACW Walloven - S/c Ele
Jenn-Air JJW9530BAB Walloven - S/c Ele
Jenn-Air JJW9530BAQ Walloven - S/c Ele
Jenn-Air JJW9530BAS Walloven - S/c Ele
Jenn-Air JJW9530BAW Walloven - S/c Ele
Jenn-Air JJW9530BCB Walloven - S/c Ele
Jenn-Air JJW9530BCW Walloven - S/c Ele
Jenn-Air JJW9530CAB Walloven - S/c Ele
Jenn-Air JJW9530CAQ Walloven - S/c Ele
Jenn-Air JJW9530CAS Walloven - S/c Ele
Jenn-Air JJW9530CAW Walloven - S/c Ele
Jenn-Air JJW9530CCB Walloven - S/c Ele
Jenn-Air JJW9530CCS Walloven - S/c Ele
Jenn-Air JJW9530CCW Walloven - S/c Ele
Jenn-Air JJW9530DDB Walloven - S/c Ele
Jenn-Air JJW9530DDP Walloven - S/c Ele
Jenn-Air JJW9530DDS Walloven - S/c Ele
Jenn-Air JJW9530DDW Walloven - S/c Ele
Jenn-Air JJW9627AAB Walloven - S/c Ele
Jenn-Air JJW9627AAQ Walloven - S/c Ele
Jenn-Air JJW9627AAS Walloven - S/c Ele
Jenn-Air JJW9627AAW Walloven - S/c Ele
Jenn-Air JJW9627BAB Walloven - S/c Ele
Jenn-Air JJW9627BAQ Walloven - S/c Ele
Jenn-Air JJW9627BAS Walloven - S/c Ele
Jenn-Air JJW9627BAW Walloven - S/c Ele
Jenn-Air JJW9627CAB Walloven - S/c Ele
Jenn-Air JJW9627CAQ Walloven - S/c Ele
Jenn-Air JJW9627CAS Walloven - S/c Ele
Jenn-Air JJW9627CAW Walloven - S/c Ele
Jenn-Air JJW9627DDB Walloven - S/c Ele
Jenn-Air JJW9627DDS Walloven - S/c Ele
Jenn-Air JJW9627DDW Walloven - S/c Ele
Jenn-Air JJW9627DDx Walloven - S/c Ele
Jenn-Air JJW9630AAB Walloven - S/c Ele
Jenn-Air JJW9630AAQ Walloven - S/c Ele
Jenn-Air JJW9630AAS Walloven - S/c Ele
Jenn-Air JJW9630AAW Walloven - S/c Ele
Jenn-Air JJW9630ACB Walloven - S/c Ele
  #2 (permalink)
Old 12-15-2011, 02:16 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Dwayne,
If the sensor resistance is 1050 to 1100 ohms, at room temp. then the sensor is in range. You may want to preheat the oven to 400 degrees for 15 or 20 minutes and check the sensor resistance, it should be 1750 ohms. If the sensor resistance is in range(+/- 10%) the sensor is OK and you'll need to replace the control, if the temperature is above 35 dgrs. off either high or low you won't be able to ajust or calibrate it.
Part number: AP4097094
Good Luck and Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electric wall oven Hshan Oven Repair (including Ranges and Cooktops) 1 01-12-2010 02:52 AM
Westinghouse Electric Wall Oven csmith5716 Oven Repair (including Ranges and Cooktops) 3 07-09-2009 12:17 PM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
Electric wall oven pendama Oven Repair (including Ranges and Cooktops) 5 05-07-2009 05:36 PM
GE Electric Wall Oven Oppy38 Oven Repair (including Ranges and Cooktops) 0 02-25-2009 02:14 PM
