Discuss
Oven doesn't bake from the top
 in
Hi, I think the top heater of my oven doesn't work. Whatever I bake almost burns from the bottom but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven doesn't bake from the top
  #1 (permalink)
Old 12-15-2011, 10:13 AM
Junior Member
Aycan is on a distinguished road
Default Oven doesn't bake from the top
Model Number: Spectra XL44   Brand: GE   Age: 5 - 10 years
I think the top heater of my oven doesn't work. Whatever I bake almost burns from the bottom but top remains white/uncooked. This is my husband's oven and I've been using it for a year only - though the oven is almost 10 years old - so I'm not really familiar with it. Neither my husband is. I would appreciate if you could explain for a dummy so that I can do it myself.
Thanks a lot!
Aycan
Ads By Google
Related Models
Hardwick SPG8441RTA719DZ Walloven - Std Dbl Oven Gas
Hardwick SPG8441RTW719DZ Walloven - Std Dbl Oven Gas
Amana SPN22G Ref - SXS/I&W
Amana SPN22G-A Ref - SXS/I&W
Amana SPN22G-AG Ref - SXS/I&W
Amana SPN22G-C Ref - SXS/I&W
Amana SPN22N Ref - SXS/I&W
Amana SPN22N-A Ref - SXS/I&W
Amana SPN22N-AG Ref - SXS/I&W
Amana SPN22N-C Ref - SXS/I&W
Amana SQ22NBL Ref - SXS/I&W
Amana SQ22NBW Ref - SXS/I&W
Amana SQD20NL Ref - SXS/I&W
Amana SQD20NW Ref - SXS/I&W
Amana SQD22NBL Ref - SXS/I&W
Amana SQD22NBW Ref - SXS/I&W
Amana SQD22NL Ref - SXS/I&W
Amana SQD22NW Ref - SXS/I&W
Amana SQD23VL Ref - SXS/I&W
Amana SQD23VW Ref - SXS/I&W
Amana SQD25MB2L Ref - SXS/I&W
Amana SQD25MB2W Ref - SXS/I&W
Amana SQD25MB3E Ref - SXS/I&W
Amana SQD25MB3L Ref - SXS/I&W
Amana SQD25MB3W Ref - SXS/I&W
Amana SQD25MB4E Ref - SXS/I&W
Amana SQD25MB4L Ref - SXS/I&W
Amana SQD25MB4W Ref - SXS/I&W
Amana SQD25MBG Ref - SXS/I&W
Amana SQD25MBL Ref - SXS/I&W
Amana SQD25MBW Ref - SXS/I&W
Amana SQD25N2L Ref - SXS/I&W
Amana SQD25N2W Ref - SXS/I&W
Amana SQD25NB2L Ref - SXS/I&W
Amana SQD25NB2W Ref - SXS/I&W
Amana SQD25NBE Ref - SXS/I&W
Amana SQD25NBL Ref - SXS/I&W
Amana SQD25NBW Ref - SXS/I&W
Amana SQD25NL Ref - SXS/I&W
Amana SQD25NW Ref - SXS/I&W
Amana SQD25TL Ref - SXS/I&W
Amana SQD25TW Ref - SXS/I&W
Amana SQD25VL Ref - SXS/I&W
Amana SQD25VW Ref - SXS/I&W
Amana SQD26VE Ref - SXS/I&W
Amana SQD26VL Ref - SXS/I&W
Amana SQD26VW Ref - SXS/I&W
Amana SR-19 Ref - SXS/I&W
Amana SR-522E Ref - SXS/I&W
Amana SR-522E-A Ref - SXS/I&W
Amana SR-522E-C Ref - SXS/I&W
Amana SR-522E-G Ref - SXS/I&W
Amana SR-522E-L Ref - SXS/I&W
Amana SR17A Ref - SXS/I&W
Amana SR17A-A Ref - SXS/I&W
Amana SR17A-AG Ref - SXS/I&W
Amana SR17A-C Ref - SXS/I&W
Amana SR17F Ref - SXS/I&W
Amana SR17G Ref - SXS/I&W
Amana SR17G-1 Ref - SXS/I&W
Amana SR17G-1-A Ref - SXS/I&W
Amana SR17G-1-AG Ref - SXS/I&W
Amana SR17G-1-C Ref - SXS/I&W
Amana SR17N Ref - SXS/I&W
Amana SR17N-A Ref - SXS/I&W
Amana SR17N-AG Ref - SXS/I&W
Amana SR17N-C Ref - SXS/I&W
  #2 (permalink)
Old 12-15-2011, 03:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Aycan,
""XL44" is not the model number. In order to provide most accurate advice we need the complete model number of the range.
The Model Number Locator will help you.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-15-2011, 04:00 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Aycan,
Hi Gene,
Now you would understand how clueless I am!! Thank you so much for your quick respond, I was about to call for a repair service because I need my oven for Christmas preparations. I thought maybe I could fix it, if it is something easy. That's why I'm here.
Anyway, I found the model number : JGBP35BEA4BB
Thanks again.
Aycan
  #4 (permalink)
Old 12-16-2011, 06:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Aycan,
The part which you called "top heater" is actually the Broil burner and it works only when you use the Broil. During the Bake the oven heats up with the bottom Bake burner.
Hopefully there is nothing serious with your oven. I found the Use and Care manual for your oven and I really recommend to read it, especially pages 10 - 13.
Make sure you did not cover the oven floor with aluminum foil. The oven has to be preheated to correct temperature prior to cooking. Also the shelf position and the size of a cooking tray you used are very important.
If you did everything correct and it's still overheating, you may want to measure the temperature inside the oven. Place an oven thermometer in the middle of the oven cavity. Set the oven to Bake at 350°F. Wait about 15 minutes after the oven preheated, open the oven door and check the thermometer. Post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat up on Conv Bake and doesn't reach temp on regular bake hargie Oven Repair (including Ranges and Cooktops) 0 01-17-2011 06:22 AM
Gas Oven Broiler Works but oven to bake will not heat Lisa Cline Oven Repair (including Ranges and Cooktops) 1 11-11-2010 12:07 PM
Bosch oven bake and convection bake not heating tbnicky Oven Repair (including Ranges and Cooktops) 1 07-27-2010 07:25 PM
Whirlpool gas oven broiler works, but oven does not bake or heat up smolesen Oven Repair (including Ranges and Cooktops) 0 03-13-2010 10:02 AM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
