The glow bar is glowing at about the same level as the small oven which lights. The large oven does not light. I want to swap the two glow bars but can't figure out how to remove them. I see a screw or two holding the metal bracket the resistor or glow bar is in. Can you tell me how to remove them? They have the same terminal clips on them and I'm pretty sure they are interchangeable. I'm an EE. Another thing I can do is either measure the current or resistance with DMM. TIA, FM
