Got a question on my Jenn-Air stove, The front burner stopped working about a year ago and I finally got around to buying a new switch thinking it may be that. Anyways it is not the switch so I believe it to be the burner itself.
Looking at the wiring diagram and at the assembly schematics I assume the hi-limit is located in the burner assembly and this may be the culprit. Is the limit switch/burner easy to get to without much disassembling and if it is the switch is it something sold separate? I didn't see a specific part on any of the exploded views.
TIA!
Derek
