Discuss
amana trbl
 in
help! when my wife recently cleaned our stove she removed the push-button control knobs to the control panel. when
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » amana trbl
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-29-2007, 12:40 PM
amanascott amanascott is offline
Junior Member
amanascott is on a distinguished road
Default amana trbl
Model Number: agds902   Brand: Amana   Age: 1 - 5 years
help! when my wife recently cleaned our stove she removed the push-button control knobs to the control panel. when she replaced the knobs the plastic female receive pins snapped on 3 of the control panel locations. i removed the control panel and ordered a replacement thru appliancepartspros, installed the new panel and tried everything successfully. i set the oven to bake at 300 and the stove worked fine. mind you this was christmas morning and we had 20 people en route for the holiday dinner. 2 hours later we cooked the christmas dinner for 2 1/2 hrs. without any trouble. 5 hours later with the oven not in use i was on the couch in the other room and the oven started non-stop beeping and flashing F-2. after searching online i found F-2 to indicate a faulty oven temperature sensor. i removed the sensor and measured the resistance at .69 ohms. is this faulty and by replacing will it solve the F-2 code on the control panel?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-30-2007, 04:35 PM
Junior Member
Default
any help????
  #3 (permalink)
Old 12-31-2007, 03:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The resistance across the oven temperature sensor wires suppose to be about 1100 Ohms at the room temperature.
If you got a different reading then the oven sensor has to be replaced.
Also check the sensor wires and the connection at the control board.
- The part number for the oven temperature sensor is AP3998148
- Here are the break down diagrams for the Amana range Model AGDS902E
Happy New year!
__________________
Professional appliance repair services in Orange County, California.
  #4 (permalink)
Old 12-31-2007, 03:53 PM
Junior Member
Default
thanks for the tip. that's the info the parts dept. thought could be wrong. i'll try a new ovn temp. sensor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana not cold on top Gopherguy Refrigerator & Freezer Repair 3 08-21-2008 12:59 PM
Amana, will not preheat PaulM Oven Repair (including Ranges and Cooktops) 6 07-14-2008 11:47 AM
Amana ref. problems wayfran1 Refrigerator & Freezer Repair 1 06-18-2008 01:02 PM
need help with Amana oven vasi1 Oven Repair (including Ranges and Cooktops) 3 11-14-2007 06:01 PM
Amana Gas Oven tlj0493 Oven Repair (including Ranges and Cooktops) 0 10-27-2007 08:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
