| » Oven temp off |
Model Number: ARG7102 Brand: Amana Age: 5 - 10 years
I Replaced the Igniter now have 3.5 amps. The burner comes on then the igniter fades out and the burner flame goes out.
With the oven set at 350 the preheat tone goes off with the oven at 225. With the oven set at 400 the preheat tone goes off with the oven at 300. Tried the temperature adjustment in the manual, did not change the oven temp by much. Which to try next Temp sensor or the controller? Before the igniter was replaced some times the oven would work fine other times it could not make or hold temp. Thanks Ads By Google Related Models |
Quote:
Quote:
Quote:
What temperature does the control display at that time? Quote:
Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
Full Model # ARG7102W P1143347NW
I think it is normal for the oven to sound preheated before reaching the full set temp. But the oven use to be little low then contitinue to raise to temp. The oven use to reach full temp. now it never reaches full set temp. The oven temp is set by a knob and the display is only a clock the temps. I posted were from a oven thermometer being read through the window. THe oven reached 300 set at 350 and reached 375 set at 400 The controll unit has a temp adjust feature to fine tune the oven it does not seam to change anything. Thanks Last edited by Snowcats : 06-26-2009 at 05:27 AM. |
Quote:
LINK > Amana ARG7102W Oven Temp. Sensor LINK > How do I check an oven temperature sensor? LINK > Amana ARG7102W/P1143347NW Electronic Control Quote:
JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
| Display Modes | |
| KitchenAid Oven not maintaining Oven Temp | Jane D | Oven Repair (including Ranges and Cooktops) | 3 | 09-28-2010 02:54 PM |
| GE Built-In Oven F2 Code Oven Temps Erratic & Over-Temp | herbl | Oven Repair (including Ranges and Cooktops) | 0 | 02-26-2010 09:08 AM |
| gas oven temp does not stay at set temp | rwarlock | Oven Repair (including Ranges and Cooktops) | 0 | 01-16-2010 07:58 AM |
| kenmore oven will light, bring oven to temp, but won't re-light after the temp.... | weedsnager | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 05:28 PM |
| Oven temp varies from display temp | topxfuelx69 | Oven Repair (including Ranges and Cooktops) | 0 | 10-14-2009 01:45 PM |
