Discuss
Troubleshoot before Board Replacement
 in
Kenmore 790.9641240, while using stove top power burner (front left) a loud pop was heard and I thought I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Troubleshoot before Board Replacement
  #1 (permalink)
Old 06-25-2009, 10:31 AM
gene.royer gene.royer is offline
Junior Member
gene.royer is on a distinguished road
Default Troubleshoot before Board Replacement
Model Number: 790.9641240   Brand: Kenmore   Age: 1 - 5 years
Kenmore 790.9641240, while using stove top power burner (front left) a loud pop was heard and I thought I saw a blue flash (like an arc) above the pan, the next day received a slight electrical tingle after turning plastic switch ON for right front burner, and again a loud pop (no apparent arc). Secured circuit breaker, opened the top backplane of the stove and found charring on the Simmer Select (P/N 316429301) and Cooktop Lockout (P/N 3164181__). Checked for grounds, by jumpering neutral and hot lead, measuring continuity w/multimeter across jumpered leads and return lead, and cycling stovetop switches to ON/OFF position. No measurable continuty was read. Ordered new Simmer Select and Cooktop Lockout boards. Is there anything else I should check before or after installing new boards?
Related Models
Kenmore 790.97471790  ELECTRIC RANGE
Kenmore 790.97475790  ELECTRIC RANGE
Kenmore 790.97476790  ELECTRIC RANGE
Kenmore 790.97478790  ELECTRIC RANGE
Kenmore 791.0  HAIR CLIPPERS
Kenmore 791.4  HAIR CLIPPERS
Kenmore 791.6102190  GAS RANGE
Kenmore 791.6102890  GAS RANGE
Kenmore 791.6112190  GAS RANGE
Kenmore 791.6112890  GAS RANGE
Kenmore 791.6162190  GAS RANGE
Kenmore 791.6162890  GAS RANGE
Kenmore 791.6262190  ELECTRIC RANGE
Kenmore 791.6262890  ELECTRIC RANGE
Kenmore 791.6272190  ELECTRIC RANGE
Kenmore 791.6272890  ELECTRIC RANGE
Kenmore 791.6302190  GAS RANGE
Kenmore 791.6302890  GAS RANGE
Kenmore 791.6412190  ELECTRIC RANGE
Kenmore 791.6412890  ELECTRIC RANGE
Kenmore 791.734891  GAS RANGE
Kenmore 791.734898  GAS RANGE
Kenmore 791.783889  GAS RANGE
Kenmore 791.7838890  KENMORE GAS RANGE
Kenmore 791.7838891  GAS RANGE
Kenmore 791.7839090  GAS RANGE
Kenmore 791.7839091  GAS RANGE
Kenmore 791.7839092  GAS RANGE
Kenmore 791.7839094  GAS RANGE
Kenmore 791.785889  GAS RANGE
Kenmore 791.7858890  KENMORE GAS RANGE
Kenmore 791.7858892  GAS RANGE
Kenmore 791.7859090  GAS RANGE
Kenmore 791.7859091  GAS RANGE
Kenmore 791.7859092  GAS RANGE
Kenmore 791.7859093  GAS RANGE
Kenmore 791.7859094  GAS RANGE
Kenmore 791.7859095  GAS RANGE
Kenmore 791.7898810  KENMORE GAS RANGE
Kenmore 791.7898814  GAS RANGE
Kenmore 791.7898815  GAS RANGE
Kenmore 791.7898884  GAS RANGE
Kenmore 791.7898885  GAS RANGE
Kenmore 791.7898894  GAS RANGE
Kenmore 791.7898895  GAS RANGE
Kenmore 791.7899010  GAS RANGE
Kenmore 791.7899011  GAS RANGE
Kenmore 791.7899012  GAS RANGE
Kenmore 791.7899080  GAS RANGE
Kenmore 791.7899081  GAS RANGE
Kenmore 791.7899082  GAS RANGE
Kenmore 791.7899090  GAS RANGE
Kenmore 791.7899091  GAS RANGE
Kenmore 791.7899092  GAS RANGE
Kenmore 791.9338911  ELECTRIC RANGE
Kenmore 791.9338913  ELECTRIC RANGE
Kenmore 791.9338981  ELECTRIC RANGE
Kenmore 791.9338983  ELECTRIC RANGE
Magic Chef 79F-5EXW
Magic Chef 79FA-5EVW
Magic Chef 79FA-5EXW
Magic Chef 79FK-5EVW
Magic Chef 79FK-5EXW Walloven - S/c Ele
Magic Chef 79FN-5EVW Walloven - S/c Ele
Magic Chef 79FN-5EXW Walloven - S/c Ele
Whirlpool 7CSE3A1
Whirlpool 7CSE3W1
Whirlpool 7CSE5A2
Whirlpool 7CSE5W2
Whirlpool 7DP840CWDB0
Whirlpool 7DP840CWDB1
Whirlpool 7DP840DWGX0
Whirlpool 7DP840SWKX0 Portable Dishwasher
Whirlpool 7DP840SWKX1 Portable Dishwasher
Whirlpool 7DP840SWSX0 Portable Dishwasher
Whirlpool 7DU1100XTSQ0 Undercounter Dishwasher
Whirlpool 7DU1100XTSS0 Undercounter Dishwasher
Whirlpool 7DU840CWDB0
Whirlpool 7DU840CWDB1
Whirlpool 7DU840DWGX0
Whirlpool 7DU850SWSQ0 Undercounter Dishwasher
Whirlpool 7DU900PCDB0
Whirlpool 7DU900PCDQ0
Whirlpool 7DU900PCDQ1
Whirlpool 7DU900PCDQ2
Whirlpool 7DU910PFGB0
Whirlpool 7DU912PFGQ0
Whirlpool 7DU920PWKB0 Undercounter Dishwasher
Whirlpool 7DU920PWKQ0 Undercounter Dishwasher
Whirlpool 7DU920PWKS0 Undercounter Dishwasher
Whirlpool 7ED0GTQXKQ00
Whirlpool 7ED0GTQXKQ01
Whirlpool 7ED0GTQXKQ02 Refrigerator
Whirlpool 7ED0GTQXMQ00 Refrigerator
Whirlpool 7ED20TKXDN00
Whirlpool 7ED20TKXDN01
Whirlpool 7ED20TKXDN02
Whirlpool 7ED20TQXFW00
Whirlpool 7ED20TQXFW01
Whirlpool 7ED20TQXFW02
Whirlpool 7ED20TQXFW03
Whirlpool 7ED20TQXFW04
Whirlpool 7ED20TQXFW05
Whirlpool 7ED22PQXDN00
Whirlpool 7ED22PQXDN01
Whirlpool 7ED22PQXFN00
Whirlpool 7ED22PQXFN01
Whirlpool 7ED22PQXFW00
Whirlpool 7ED22PQXFW01
Whirlpool 7ED25DQXFW00
Whirlpool 7ED25DQXFW01
Whirlpool 7ED25DQXFW02
Whirlpool 7ED25PQXDW00
Whirlpool 7ED25PQXDW01
Whirlpool 7ED25PQXDW02
Whirlpool 7ED27DQXDN00
Whirlpool 7ED27DQXDN01
Whirlpool 7ED27DQXDN02
Whirlpool 7ED27DQXDW02
Whirlpool 7ED27DQXFN00
  #2 (permalink)
Old 06-25-2009, 12:45 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool Model number
That model number is incomplete or incorrect.
Quote:
Is there anything else I should check before installing new boards?
Other than shorts to ground and/or poor connections, I can't think of anything.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 06-25-2009, 01:01 PM
Junior Member
Default Thanks Dan.
I used the whole part number (790.9641240) I found on some documentation delivered with range. The front cover of the Kenmore Electric Range Use & Care Guide indicates model 790 with several series (i.e. 9621*, 9622* etc.) mine happens to be 9641*; hence, I probably should refer to the part number as 790.9641.
Sincerely,
  #4 (permalink)
Old 06-25-2009, 11:28 PM
Senior Expert
APP Volunteer
Cool Not really needed at the moment but...
Quote:
I used the whole [model] number (790.9641240) I found on some documentation delivered with range.
Documentation rarely has the complete information. The complete information will usually only be found right on the appliance's model and serial number identification tag. It is the only reliable place to get it anyway.
Possibilities for what you originally supplied include:
790.96412400
790.96412401
790.96412403
790.96412404
790.96412406
790.96412407
790.96412408
790.96412409
790.9641240A
790.9641240B
790.9641240C
790.9641240D
790.9641240E
You can find tips for locating the actual model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
It is a model number not a part number and the above is even more incomplete than the first. You would be best to only use the complete information as found right on the appliance's identification tag.
JFYI
Dan O.
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE refrigerator board replacement gassian Refrigerator & Freezer Repair 1 06-02-2009 09:40 AM
Circuit board/timer replacement piobman Dishwasher Repair 0 01-23-2009 05:53 PM
Control Board replacement for a GE stove. fireman Oven Repair (including Ranges and Cooktops) 1 08-26-2008 09:28 AM
GE Oven Controller Board Replacement smtowne@cox.net Oven Repair (including Ranges and Cooktops) 1 04-11-2008 03:38 PM
Circuit board replacement tobrouhard Refrigerator & Freezer Repair 5 08-16-2007 06:24 AM
