jake59
#1 Posted : Wednesday, June 24, 2009 9:23:46 AM(UTC)
jake59
My broiler will work, but the oven will not ignite. The igniter glows and appears to be working properly. Thank You in advance for any help recieved
Dan O.
#2 Posted : Wednesday, June 24, 2009 10:37:16 AM(UTC)
Dan O.
Quote:
broiler will work but the [bake burner] will not ignite. The igniter glows
Your symptom could be caused by a defective oven gas valve or a 'weak' oven ignitor. (And yes, an ignitor can glow and still be defective.) The only way to determine which is responsible is to test the amperage draw on the ignition circuit.
LINK > Whirlpool GW395LEGB6 Oven Ignitor
The ignitor on your model should draw 3.2 to 3.6 amps. Anything else and it is defective. If it is drawing within those tolerances, the oven valve would likely be most suspect.
LINK > Whirlpool GW395LEGB6 Oven Gas Valve
You can read how such a system works at the following link:
LINK > Understanding Gas Oven Ignition Systems
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Top Oven Will Not Ignite (Oven Repair (including Ranges and Cooktops))
by tdolecek 8/22/2013 11:46:26 AM(UTC)
by montville524 9/10/2012 7:01:58 AM(UTC)
Bosch oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Stan Twardowski 4/16/2012 5:57:48 AM(UTC)
OVEN WILL NOT IGNITE (but igniter glows) (Oven Repair (including Ranges and Cooktops))
by dennis728 2/7/2011 5:44:03 PM(UTC)
Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Tracy H 12/19/2010 4:30:33 PM(UTC)
top burners & oven will not ignite (Oven Repair (including Ranges and Cooktops))
by cortlandt32 10/22/2010 5:16:37 AM(UTC)
Oven will not ignite, but broiler does (Oven Repair (including Ranges and Cooktops))
by BillWat 3/28/2010 4:12:20 PM(UTC)
by weberce13 1/12/2010 8:31:07 AM(UTC)
Whirlpool gas range oven will not ignite (Oven Repair (including Ranges and Cooktops))
by kamzuk 1/2/2010 2:59:23 PM(UTC)
storm now oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bonnie32f 8/17/2009 6:48:24 AM(UTC)
Gas Range Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by Clubogilvie@yahoo.com 3/26/2009 12:03:07 PM(UTC)
Whirlpool gas oven will not ignite (Oven Repair (including Ranges and Cooktops))
by adamerik 11/5/2008 2:34:26 PM(UTC)
by gordo634 7/22/2008 5:45:05 AM(UTC)
Tappan 12-1863-10/03 Oven will not ignite (Oven Repair (including Ranges and Cooktops))
by areamon 6/4/2008 12:36:22 PM(UTC)
Burners and oven will not ignite (Oven Repair (including Ranges and Cooktops))
by bren 7/26/2007 12:32:27 PM(UTC)
