Discuss
oven is dead
 in
performed a self cleaning and everything worked fine. Next time I tried the oven, you could select broil, bake etc
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven is dead
  #1 (permalink)
Old 06-24-2009, 10:17 AM
wayne hrynyk wayne hrynyk is offline
Junior Member
wayne hrynyk is on a distinguished road
Default oven is dead
Model Number: kebs107dw1   Brand: Kitchen Aid   Age: 5 - 10 years
Next time I tried the oven, you could select broil, bake etc but the oven would not start. The oven indicates it was working but it does not.
I pulled the oven out and now there is no indication at all.
Checked for 240volts at terminal block and all is good.
Unfortunately there is no wiring diagram with the unit.
I bought this unit brand new.
Any ideas???
Related Models
Whirlpool KEBS107DWH1
Whirlpool KEBS107DWH10
Whirlpool KEBS107DWH11
Whirlpool KEBS107DWH2
Whirlpool KEBS107DWH4
Whirlpool KEBS107DWH6
Whirlpool KEBS107DWH7
Whirlpool KEBS107DWH8
Whirlpool KEBS107DWH9
Whirlpool KEBS107SBL00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS107SSS00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS107SWH00 30" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS107YAL0
Whirlpool KEBS107YAL1
Whirlpool KEBS107YAL2
Whirlpool KEBS107YAL3
Whirlpool KEBS107YBL0
Whirlpool KEBS107YBL1
Whirlpool KEBS107YBL2
Whirlpool KEBS107YBL3
Whirlpool KEBS107YWH0
Whirlpool KEBS107YWH1
Whirlpool KEBS107YWH2
Whirlpool KEBS107YWH3
Whirlpool KEBS141SBL0
Whirlpool KEBS145SBL0
Whirlpool KEBS145SBL1
Whirlpool KEBS146SBL1
Whirlpool KEBS146SBL2
Whirlpool KEBS146WBL0
Whirlpool KEBS146WBL1
Whirlpool KEBS146WBL2
Whirlpool KEBS147DBL1
Whirlpool KEBS147DBL10
Whirlpool KEBS147DBL11
Whirlpool KEBS147DBL2
Whirlpool KEBS147DBL4
Whirlpool KEBS147DBL6
Whirlpool KEBS147DBL7
Whirlpool KEBS147DBL8
Whirlpool KEBS147DBL9
Whirlpool KEBS147DWH1
Whirlpool KEBS147DWH10
Whirlpool KEBS147DWH11
Whirlpool KEBS147DWH2
Whirlpool KEBS147DWH4
Whirlpool KEBS147DWH6
Whirlpool KEBS147DWH7
Whirlpool KEBS147DWH8
Whirlpool KEBS147DWH9
Whirlpool KEBS176SBL0
Whirlpool KEBS176SBL1
Whirlpool KEBS176SBL2
Whirlpool KEBS176SBL3
Whirlpool KEBS176WBL0
Whirlpool KEBS176WBL1
Whirlpool KEBS176WBL2
Whirlpool KEBS176WBL3
Whirlpool KEBS177BAL0
Whirlpool KEBS177BAL1
Whirlpool KEBS177BAL2
Whirlpool KEBS177BAL3
Whirlpool KEBS177BBL0
Whirlpool KEBS177BBL1
Whirlpool KEBS177BBL2
Whirlpool KEBS177BBL3
Whirlpool KEBS177BWH0
Whirlpool KEBS177BWH1
Whirlpool KEBS177BWH2
Whirlpool KEBS177BWH3
Whirlpool KEBS177DAL1
Whirlpool KEBS177DAL2
Whirlpool KEBS177DAL4
Whirlpool KEBS177DAL6
Whirlpool KEBS177DAL7 27" Built - in Electric Single Oven Thermal Convect
Whirlpool KEBS177DAL8
Whirlpool KEBS177DBL1
Whirlpool KEBS177DBL10
Whirlpool KEBS177DBL11
Whirlpool KEBS177DBL2
Whirlpool KEBS177DBL4
Whirlpool KEBS177DBL6
Whirlpool KEBS177DBL7 27" Built - in Electric Single Oven Thermal Convect
Whirlpool KEBS177DBL8
Whirlpool KEBS177DBL9
Whirlpool KEBS177DBS10
Whirlpool KEBS177DBS11
Whirlpool KEBS177DBS6
Whirlpool KEBS177DBS7 27" Built - in Electric Single Oven Thermal Convect
Whirlpool KEBS177DBS8
Whirlpool KEBS177DBS9
Whirlpool KEBS177DBT10
Whirlpool KEBS177DBT11
Whirlpool KEBS177DBT6
Whirlpool KEBS177DBT7 27" Built - in Electric Single Oven Thermal Convect
Whirlpool KEBS177DBT8
Whirlpool KEBS177DBT9
Whirlpool KEBS177DSS10
Whirlpool KEBS177DSS11
Whirlpool KEBS177DSS7
Whirlpool KEBS177DSS8
Whirlpool KEBS177DSS9
Whirlpool KEBS177DWH1
Whirlpool KEBS177DWH10
Whirlpool KEBS177DWH11
Whirlpool KEBS177DWH2
Whirlpool KEBS177DWH4
Whirlpool KEBS177DWH6
Whirlpool KEBS177DWH7 27" Built - in Electric Single Oven Thermal Convect
Whirlpool KEBS177DWH8
Whirlpool KEBS177DWH9
Whirlpool KEBS177SBL0
Whirlpool KEBS177SBL00 27" Built - in Electric Single Oven Thermal Convection
Whirlpool KEBS177SBL01 27" Built - in Electric Single Oven Thermal Convection
Whirlpool KEBS177SSS00 27" Built - in Electric Single Oven Thermal Convection
Whirlpool KEBS177SSS01 27" Built - in Electric Single Oven Thermal Convection
Whirlpool KEBS177SWH0
Whirlpool KEBS177SWH00 27" Built - in Electric Single Oven Thermal Convection
Whirlpool KEBS177SWH01 27" Built - in Electric Single Oven Thermal Convection
Whirlpool KEBS177SWH1
  #2 (permalink)
Old 06-24-2009, 01:18 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool Open safety?
That model number appears to be incomplete (eg. kebs107dw__1).
Did you look inside the control console? That is a common location for it.
Assuming your appliance's model number is KEBS107DWH1, you can download a PDF copy of the wiring information at the following link:
LINK > Whirlpool KEBS107DWH1 'Tech Sheet'
The oven elements look to be fused or safety protected with a thermostat. The only one I see listed in the parts list is linked below.
LINK > KitchenAid KEBS107DWH1 Safety(?) Thermostat
If such a device was open, it could prevent all elements from heating but not affect the rest of the appliance's apparent functioning.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 06-24-2009, 03:51 PM
Junior Member
Default
Dan O
I have relooked at the model number and you are correct it should be dw1
also so you know i am in Canada so the model starts with a Y.
I also talked with whirlpool and they advise me that it may be dwh1--the wh stands for white which would make sense.
I will look at the thermostat you suggest.
I did look inside the covers but no wiring diagram seems to be hidden there.
  #4 (permalink)
Old 06-25-2009, 01:26 AM
Senior Expert
APP Volunteer
Cool
That is not what I said it should be. That is what you originally posted.
You didn't supply that when you posted the model number.
Hopefully your model has one because the wiring diagram I looked at isn't for a model starting with a "Y".
Good luck!
Dan O.
www.Appliance411.ca
=D~~~~~~
  #5 (permalink)
Old 06-26-2009, 05:03 PM
Junior Member
Default
Hi Dan O
Sorry for misleading you.
When I had talked with the manufacturer they advised me that the Y did not mean anything except that it was sold in Canada.
I did find the thermostat and it was dead. Changed it but the control panel is still dead.
The complete model # is
YKEBS107DW1
  #6 (permalink)
Old 06-26-2009, 08:39 PM
Senior Expert
APP Volunteer
Question "Dead"??
It is always best to supply exactly what information is listed on the appliance's identification tag. That's why it's there.
No lights or anything???
Dan O.
www.Appliance411.ca
=D~~~~~~
  #7 (permalink)
Old 06-28-2009, 06:07 PM
Junior Member
Default
Dan O
Found the problem the white neutral wire became disconnected in the box.
The unit is hard wired and I suspect when I lifted it out I pulled on the wiring harness and the neutral became disconnected
I reconnected and all works perfectly. It was the thermostat.
Thanks Dan O I appreciate your help
  #8 (permalink)
Old 06-30-2009, 12:05 AM
Senior Expert
APP Volunteer
Thumbs up Fixed
Quote:
Found the white neutral wire became disconnected in the box. I reconnected and all works perfectly.
Glad to hear it. Thanks for the follow up.
Dan O.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dead oven bethjsher Oven Repair (including Ranges and Cooktops) 4 02-20-2009 11:05 AM
KitchenAid Oven is Dead texanokie Oven Repair (including Ranges and Cooktops) 2 12-09-2008 10:48 AM
Dead oven and clock ALTHEA MCGOWAN Oven Repair (including Ranges and Cooktops) 0 04-05-2008 08:38 AM
Thermador oven dead Cat Oven Repair (including Ranges and Cooktops) 3 11-19-2007 03:37 PM
GE oven dead after cleancycle Diet Oven Repair (including Ranges and Cooktops) 7 09-11-2007 02:32 PM
