Discuss
IF Oven is to Hot, can it cause a Fire?
 in
I recently moved into a senior apartment complex & have had issues with my oven being hotter than it should
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » IF Oven is to Hot, can it cause a Fire?
  #1 (permalink)
Old 12-12-2011, 10:41 AM
Junior Member
cvhayes is on a distinguished road
Default IF Oven is to Hot, can it cause a Fire?
Brand: GE   Age: 1 - 5 years
I recently moved into a senior apartment complex & have had issues with my oven being hotter than it should be. Baked goods are over-cooking, quickly & I've burnt more items than I care to count. The other day, a towel that I had on the oven door handle caught fire. I believe the "vents" at the top of the door was what started it. The towel was Not in the oven! Now, I am being told that I am responsible for the damage to the stove & the floor. I don't believe that I am. I think the faulty oven is at fault. Could a towel catch fire just by hanging on the handle?? I've hung a towel there for Years & this is the first time I've had one catch fire.
Any advice will be terribly appreciated ~ Thank you!!
Ads By Google
  #2 (permalink)
Old 12-13-2011, 05:11 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
If the oven is working correctly and the towel is just a regular clean hand towel I would not think so.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 12-14-2011, 04:44 PM
Member
ramblinche81 is on a distinguished road
Default Not likely to auto combust outside the oven.
Auto Ignition temp for a dry cotton towel is over 240degrees.
A cotton towel with vegetable oil or sugar (common while cooking ?) is well below 200degrees.
While it might be hard to admit....the chance the towel was stuck in the door is more likely than the door leaking heat over 240degrees.
You can always invite the maintenance main over for lunch and let him have a look with the oven on. If it leaked heat before, it will leak again.
Is it a single or double oven ?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heat & Glow Gas-Fire Place w/o Fire ●●●●●● Heating, Ventilation, and Air Conditioning (HVAC) 0 11-07-2010 11:06 AM
GE oven fire Stacey72 Oven Repair (including Ranges and Cooktops) 3 05-31-2009 05:01 PM
oven won't fire curt Oven Repair (including Ranges and Cooktops) 1 12-06-2007 01:39 PM
Oven Won't Fire OttoZ Oven Repair (including Ranges and Cooktops) 0 11-11-2007 09:07 AM
