| » Error Code F-2 |
Model Number: 3468XTP Brand: Magic Chef Age: More than 10 years
OUT OF THE BLUE MY OVEN SPEWED OUT AN ERROR CODE AND THE OVEN WAS NOT EVEN ON .WHEN I DID ATTEMPT TO BAKE SOMETHING IN THE OVEN IT STARTED TO WARM UP AND NOT TO MUCH LATER THE CODE CAME BACK AND TURNED THE OVEN OFF BUT KEPT BEEPING THE F-2 ERROR CODE .WHEN I LOOKED UP THIS ERROR CODE FOR MY BRAND OVEN I READ THIS :F2Oven temperature too hotReplace relay board, if present, or oven temperature sensor (RTD). Check sensor harness.
HOW DO I KNOW IF MY OVEN HAS A RELAY BOARD OR DO I ASSUME THE PROBLEM HAS TO BE THE (RTD)?..THANKS FOR ANY HELP!! Related Models |
Quote:
I suggest you can an authorized Maytag/Whirlpool service agent for service. JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
Coupl not find info on a XTP only see XTW and XTA units.
I am assuming it is a gas unit. The sensors are pretty standard as to how they work. At the below link check out #'s 4 , 5 and 22 http://www.applianceaid.com/gas.html Check it with a meter You will notice that the resistance rises as the temperature rises so if you have an open or bad connection from the sensor to the board it will also give a false high temp.
__________________
| Display Modes | |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 0 | 05-18-2009 03:11 PM |
| Ge Error Code F2 | SHADETREE101 | Oven Repair (including Ranges and Cooktops) | 6 | 04-13-2009 08:02 PM |
| error code f3 | viejo sam | Oven Repair (including Ranges and Cooktops) | 0 | 02-10-2009 05:30 PM |
| F5 error code | kenro | Oven Repair (including Ranges and Cooktops) | 1 | 06-28-2008 11:06 AM |
| dlf error code | sjf961 | Washer Repair | 1 | 03-18-2008 07:57 PM |
