Discuss
bake element will not heat
 in
bake element arced and melted. I replaced with new element, but the element will not heat. If the control nob
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bake element will not heat
  #1 (permalink)
Old 06-23-2009, 08:36 AM
Junior Member
pdqhale is on a distinguished road
Default bake element will not heat
Model Number: arr6300ww   Brand: Amana   Age: 5 - 10 years
bake element arced and melted. I replaced with new element, but the element will not heat. If the control nob is manipulated up/down or left/right rather than around, the element can be caused to turn on. The thermostat seems to still work, because I can heat the oven with broil element and it will reach desired temperature very slowly and then turn off. This particular version of the Amana arr6300ww serial #9610194218 has a separate thermostat and auxiliary switch next to each other. What do I replace? The thermostat? The auxiliary switch? or both?
Ads By Google
Related Models
Amana ARR6300WW Range - S/c S/i Ddraft Ele
Amana ARR630L Range - S/c S/i Ddraft Ele
Amana ARR630L1 Range - S/c S/i Ddraft Ele
Amana ARR630LL Range - S/c S/i Ddraft Ele
Amana ARR630W Range - S/c S/i Ddraft Ele
Amana ARR630W1 Range - S/c S/i Ddraft Ele
Amana ARR630WW Range - S/c S/i Ddraft Ele
Amana ARR632E Range - S/c S/i Ddraft Ele
Amana ARR632WW Range - S/c S/i Ddraft Ele
Amana ARR633E Range - S/c S/i Ddraft Ele
Amana ARR633W Range - S/c S/i Ddraft Ele
Amana ARR633WW Range - S/c S/i Ddraft Ele
Amana ARR6400L Range - S/c S/i Ddraft Gas
Amana ARR6400LL Range - S/c S/i Ddraft Gas
Amana ARR6400W Range - S/c S/i Ddraft Gas
Amana ARR6400WW Range - S/c S/i Ddraft Gas
Amana ARR6420CC Range - S/c S/i Ddraft Gas
Amana ARR6420WW Range - S/c S/i Ddraft Gas
Amana ARRS6500E Range - S/c S/i Ddraft Gas
Amana ARRS6500LL Range - S/c S/i Ddraft Gas
Amana ARRS6500WW Range - S/c S/i Ddraft Gas
Amana ARRS6550E Range - S/c S/i Ddraft Gas
Amana ARRS6550LL Range - S/c S/i Ddraft Gas
Amana ARRS6550WW Range - S/c S/i Ddraft Gas
Amana ARS14 Misc / Accessory
Amana ARS14L Misc / Accessory
Amana ARS15 Misc / Accessory
Amana ARS15L Misc / Accessory
General Electric ARS18DAV1 Room air conditioner
General Electric ARS18DBV1 Room air conditioner
General Electric ARS18DBV2 Room air conditioner
Amana ARS2304AB Ref - SXS/I&W
Amana ARS2304AC Ref - SXS/I&W
Amana ARS2304AW Ref - SXS/I&W
Amana ARS2364AB Ref - SXS/I&W
Amana ARS2364AC Ref - SXS/I&W
Amana ARS2364AW Ref - SXS/I&W
Amana ARS2365AB Ref - SXS/I&W
Amana ARS2365AC Ref - SXS/I&W
  #2 (permalink)
Old 06-23-2009, 11:17 AM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool More information needed
We would also need the appliance's manufacturing (MF G) number to properly identify the appliance in question. It starts with the letter P...
Quote:
If the control knob is manipulated...
The knob for the thermostat??
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 06-23-2009, 02:07 PM
Junior Member
Default
Dan O.
=D~~~~~~
Dan O.
The MF G number is P1142669NWW
And yes, it is the thermostat nob that was moved.
  #4 (permalink)
Old 06-23-2009, 02:44 PM
Senior Expert
APP Volunteer
Unhappy Thermostat likely needed
Quote:
yes, it is the thermostat knob that was moved [to get the bake element to come on].
Than my guess is the contact in the thermostat for the bake element is malfunctioning, likely needing the thermostat to be replaced to correct the condition... whether it is controlling the broil element at the right temperature or not.
Unfortunately it looks like the thermostat (part # Y0316885 or R0161098) for your model has been discontinued and is no longer available. I don't know if you'd be able to locate anyone with old stock of it still kicking around. One possibility might be the following link:
LINK > Amana R0161098 Thermostat - old stock
JMO
Dan O.
=D~~~~~~
  #5 (permalink)
Old 06-23-2009, 05:26 PM
Junior Member
Default
JMO
Dan O.
=D~~~~~~
Thanks Dan O
I will give it a try
Reply
« help! | Wont heat »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake element does not heat jfm1234 Oven Repair (including Ranges and Cooktops) 0 12-09-2009 08:02 AM
bake element no heat rolf Oven Repair (including Ranges and Cooktops) 3 06-25-2009 09:59 PM
Bake element will not heat djmikey9 Oven Repair (including Ranges and Cooktops) 2 05-07-2009 11:51 AM
Oven Bake Element will not heat up wcwilson1 Oven Repair (including Ranges and Cooktops) 1 04-16-2009 08:56 AM
bake element only heat on oneside ssrocco Oven Repair (including Ranges and Cooktops) 0 02-09-2009 02:50 PM
