gianca
#1 Posted : Tuesday, June 23, 2009 5:30:09 AM(UTC)
gianca
rt frt burner will not turn off.disconnected potentiometer with same result.
replaced main power panel last year(one with clock and oven controls)
it might be the other electronic control board but not sure...any suggestions
thanks.....gianca
gianca
#2 Posted : Tuesday, June 23, 2009 6:22:54 AM(UTC)
gianca
this is from gianca
tested potentiometers to be ok .....diconnected lead to burner from elect
control panel AP4374771.burner now remains off.
there dose not seem to be anything else in circuit that could be at fault so im leaning to replace the elect board.....if anything else should be checked
please advise as board is expensive......thanks
Dan O.
#3 Posted : Tuesday, June 23, 2009 10:30:11 AM(UTC)
Dan O.
Quote:
replaced main power panel (one with clock and oven controls) last year
That should have nothing to do with operation of the surface elements.
Quote:
rt frt burner will not turn off. it might be the other electronic control board
That would be my guess as well. I can't see anything else being the cause if the element can not be turned off and when ON is glowing at full power (ie. red hot).
LINK > Surface Element User Interface Board
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
