The front right burner on my Roper electric range won't heat up. I switched the coil with the back burner of that size and the coil heats as per usual on the back burner, so I know it's not the coil. Is there a seperate fuse for each of the four burners? Any suggestions?
Could be the socket the burner plug into or the burner switch.
