Discuss
Oven won't turn off
 in
Oven heats up (regular and convection), temp changes on indicator panel until set temp achieved, and beeps. However elements don't
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't turn off
  #1 (permalink)
Old 06-22-2009, 07:30 PM
Junior Member
JDMACRAE is on a distinguished road
Default Oven won't turn off
Model Number: wup39500   Brand: Whirlpool   Age: More than 10 years
Oven heats up (regular and convection), temp changes on indicator panel until set temp achieved, and beeps. However elements don't turn off. Lock indicator comes on when the oven gets hot enough. Temp sensor has been replaced, clock board, relay board and ribbon cable sent to a service depot but no fault found. Any ideas? JD
Ads By Google
Related Models
Whirlpool WVP5000SQ0 Laundry Tower
Whirlpool WVP8600SB0 Laundry Tower
Whirlpool WVP8600ST0 Laundry Tower
Whirlpool WVP8600SU0 Laundry Tower
Whirlpool WVP8600SW0 Laundry Tower
Whirlpool WVP9000SB0 Laundry Tower
Whirlpool WVP9000ST0 Laundry Tower
Whirlpool WVP9000SU0 Laundry Tower
Whirlpool WVP9000SW0 Laundry Tower
General Electric WVSR1060A0AA Washer
General Electric WVSR1060A0WW Washer
General Electric WVSR1060A1AA Washer
General Electric WVSR1060A1WW Washer
General Electric WVSR1060A2AA Washer
General Electric WVSR1060A2WW Washer
General Electric WVSR1060B0WW Washer
General Electric WVSR1060B3WW Washer
General Electric WVSR1060B4WW Washer
General Electric WVSR1060D0WW Washer
General Electric WVSR1060D2WW Washer
General Electric WVSR1060D5WW Washer
General Electric WVSR1060DAWW Washer
General Electric WVSR1060DBWW Washer
General Electric WVSR1060DCWW Washer
General Electric WVSR1060DDWW Washer
General Electric WVSR1060G0WW Washer
General Electric WVSR1060G2WW Washer
General Electric WVXR1040T2WW Washer
General Electric WVXR1040T3WW Washer
General Electric WVXR1040T4WW Washer
General Electric WVXR1040T5WW Washer
General Electric WVXR1040T8WW Washer
General Electric WVXR1040TAWW Washer
Jenn-Air WW2460B Walloven - S/c Ele
Jenn-Air WW2460W Walloven - S/c Ele
Jenn-Air WW27110B Walloven - S/c Ele
Jenn-Air WW27110W Walloven - S/c Ele
Jenn-Air WW27210B Walloven - S/c Ele
Jenn-Air WW27210P Walloven - S/c Ele
Jenn-Air WW27210PF Walloven - S/c Ele
Jenn-Air WW27210PG Walloven - S/c Ele
Jenn-Air WW27210PK Walloven - S/c Ele
Jenn-Air WW27210PR Walloven - S/c Ele
Jenn-Air WW27210PU Walloven - S/c Ele
Jenn-Air WW27210W Walloven - S/c Ele
Jenn-Air WW27430B Walloven - S/c Ele
Jenn-Air WW27430BC Walloven - S/c Ele
Jenn-Air WW27430P Walloven - S/c Ele
Jenn-Air WW27430PF Walloven - S/c Ele
Jenn-Air WW27430PG Walloven - S/c Ele
Jenn-Air WW27430PK Walloven - S/c Ele
Jenn-Air WW27430PR Walloven - S/c Ele
Jenn-Air WW27430PU Walloven - S/c Ele
Jenn-Air WW27430W Walloven - S/c Ele
Jenn-Air WW27430WC Walloven - S/c Ele
Jenn-Air WW2750B Walloven - S/c Ele
Jenn-Air WW2750W Walloven - S/c Ele
Jenn-Air WW2780B Walloven - S/c Ele
Jenn-Air WW2780B-C Walloven - S/c Ele
Jenn-Air WW2780W Walloven - S/c Ele
Jenn-Air WW2780W-C Walloven - S/c Ele
Whirlpool WW29000SU0 Laundry Worksurface
Whirlpool WW29000SW0 Laundry Worksurface
Jenn-Air WW30110B Walloven - S/c Ele
Jenn-Air WW30110W Walloven - S/c Ele
Jenn-Air WW30430B Walloven - S/c Ele
Jenn-Air WW30430P Walloven - S/c Ele
Jenn-Air WW30430PC Walloven - S/c Ele
Jenn-Air WW30430PF Walloven - S/c Ele
Jenn-Air WW30430PG Walloven - S/c Ele
Jenn-Air WW30430PK Walloven - S/c Ele
Jenn-Air WW30430PR Walloven - S/c Ele
Jenn-Air WW30430PU Walloven - S/c Ele
Jenn-Air WW30430W Walloven - S/c Ele
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
Maytag WW600 Mwave - Cntrtp / Stand Alone
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
  #2 (permalink)
Old 06-23-2009, 03:15 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Could not find any info using the given Model Number.
Does sound like a control board problem.
The reason I would lean towards the control board is that you say "elements do not turn off" cannot see two relays on the relay board sticking closed at the same time.
__________________
  #3 (permalink)
Old 06-23-2009, 09:32 AM
Junior Member
Default Control board
Thanks - that's what it looks like - interesting that the cancel button shuts everything off. Unfortunatly, new control boards do not seem to be available unless someone out there knows a source. Will try resoldering the control board and relay board just in case. Hate to scrap the whole stove for this problem. JD
  #4 (permalink)
Old 06-23-2009, 10:04 AM
Senior Expert
APP Volunteer
Default
Do a google, there are companies out there that will repair many of the older boards.
__________________
  #5 (permalink)
Old 06-23-2009, 10:15 AM
Junior Member
Default Control board repair
Thanks - I'll give it a try. JD
  #6 (permalink)
Old 06-23-2009, 10:47 AM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool Canadian appliance
That's because it appears to be a Canadian model. The OP will likely need to contact a *local* Inglis or Canadian Whirlpool dealer or parts supplier to try to trace it.
JMO
Dan O.
www.Appliance411.ca
The Appliance Information Site
=D~~~~~~
  #7 (permalink)
Old 06-23-2009, 06:54 PM
Junior Member
Default Canadian Model
You are correct - a Canadian model. Clock board, relay baord, ribbon cable and sensor were all sent to a local repair depot but they couldn't find a fault. JD
  #8 (permalink)
Old 06-24-2009, 03:20 AM
Senior Expert
APP Volunteer
Default
When you are preheating do the elements come on full (bright red).
Since cancel shuts them off you may have a short to the frame and they are running on 120 volts. This is a long shot but a possibility.
A wiring diagram would be a big help here.
May need a cross reference to the US unit.
I do not have this but perhaps Dan O does or knows of a way to get it.
__________________
  #9 (permalink)
Old 06-24-2009, 07:56 AM
Junior Member
Thanks for the feedback - will check this evening. JD
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven will not turn off lbrown Oven Repair (including Ranges and Cooktops) 1 03-23-2011 08:31 AM
Set-in oven won't turn off. tdtk42 Oven Repair (including Ranges and Cooktops) 2 11-07-2009 09:14 AM
Maytag Stove/Oven - oven will not turn off bodnarja Oven Repair (including Ranges and Cooktops) 6 11-01-2009 02:23 AM
Oven won't turn off rg99 Oven Repair (including Ranges and Cooktops) 8 03-13-2009 04:11 AM
Oven won't turn off toebridge Oven Repair (including Ranges and Cooktops) 1 01-31-2009 06:03 AM
