Discuss
Surface element does not heat
 in
The large dual element on my range doesn't heat up. I removed the element and tested the resistance, read approximately
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Surface element does not heat
  #1 (permalink)
Old 06-21-2009, 10:30 AM
Junior Member
lonepalm is on a distinguished road
Default Surface element does not heat
Model Number: 790.99013   Brand: Kenmore   Age: 5 - 10 years
The large dual element on my range doesn't heat up. I removed the element and tested the resistance, read approximately 80 ohms. I tested another element and only read 23 ohms. According to some online research I found it should be between 19 & 115 ohms. I tried swapping switches between elements and the problem remained with the same element. Could it be the power control boards or is my resistance to high for that element?
Ads By Google
Related Models
Kenmore 791.0  HAIR CLIPPERS
Kenmore 791.4  HAIR CLIPPERS
Kenmore 791.6102190  GAS RANGE
Kenmore 791.6102890  GAS RANGE
Kenmore 791.6112190  GAS RANGE
Kenmore 791.6112890  GAS RANGE
Kenmore 791.6162190  GAS RANGE
Kenmore 791.6162890  GAS RANGE
Kenmore 791.6262190  ELECTRIC RANGE
Kenmore 791.6262890  ELECTRIC RANGE
Kenmore 791.6272190  ELECTRIC RANGE
Kenmore 791.6272890  ELECTRIC RANGE
Kenmore 791.6302190  GAS RANGE
Kenmore 791.6302890  GAS RANGE
Kenmore 791.6412190  ELECTRIC RANGE
Kenmore 791.6412890  ELECTRIC RANGE
Kenmore 791.734891  GAS RANGE
Kenmore 791.734898  GAS RANGE
Kenmore 791.783889  GAS RANGE
Kenmore 791.7838890  KENMORE GAS RANGE
Kenmore 791.7838891  GAS RANGE
Kenmore 791.7839090  GAS RANGE
Kenmore 791.7839091  GAS RANGE
Kenmore 791.7839092  GAS RANGE
Kenmore 791.7839094  GAS RANGE
Kenmore 791.785889  GAS RANGE
Kenmore 791.7858890  KENMORE GAS RANGE
Kenmore 791.7858892  GAS RANGE
Kenmore 791.7859090  GAS RANGE
Kenmore 791.7859091  GAS RANGE
Kenmore 791.7859092  GAS RANGE
Kenmore 791.7859093  GAS RANGE
Kenmore 791.7859094  GAS RANGE
Kenmore 791.7859095  GAS RANGE
Kenmore 791.7898810  KENMORE GAS RANGE
Kenmore 791.7898814  GAS RANGE
Kenmore 791.7898815  GAS RANGE
Kenmore 791.7898884  GAS RANGE
Kenmore 791.7898885  GAS RANGE
Kenmore 791.7898894  GAS RANGE
Kenmore 791.7898895  GAS RANGE
Kenmore 791.7899010  GAS RANGE
Kenmore 791.7899011  GAS RANGE
Kenmore 791.7899012  GAS RANGE
Kenmore 791.7899080  GAS RANGE
Kenmore 791.7899081  GAS RANGE
Kenmore 791.7899082  GAS RANGE
Kenmore 791.7899090  GAS RANGE
Kenmore 791.7899091  GAS RANGE
Kenmore 791.7899092  GAS RANGE
Kenmore 791.9338911  ELECTRIC RANGE
Kenmore 791.9338913  ELECTRIC RANGE
Kenmore 791.9338981  ELECTRIC RANGE
Kenmore 791.9338983  ELECTRIC RANGE
Magic Chef 79F-5EXW
Magic Chef 79FA-5EVW
Magic Chef 79FA-5EXW
Magic Chef 79FK-5EVW
Magic Chef 79FK-5EXW Walloven - S/c Ele
Magic Chef 79FN-5EVW Walloven - S/c Ele
Magic Chef 79FN-5EXW Walloven - S/c Ele
Whirlpool 7CSE3A1
Whirlpool 7CSE3W1
Whirlpool 7CSE5A2
Whirlpool 7CSE5W2
Whirlpool 7DP840CWDB0
Whirlpool 7DP840CWDB1
Whirlpool 7DP840DWGX0
Whirlpool 7DP840SWKX0 Portable Dishwasher
Whirlpool 7DP840SWKX1 Portable Dishwasher
Whirlpool 7DP840SWSX0 Portable Dishwasher
Whirlpool 7DU1100XTSQ0 Undercounter Dishwasher
Whirlpool 7DU1100XTSS0 Undercounter Dishwasher
Whirlpool 7DU840CWDB0
Whirlpool 7DU840CWDB1
Whirlpool 7DU840DWGX0
Whirlpool 7DU850SWSQ0 Undercounter Dishwasher
Whirlpool 7DU900PCDB0
Whirlpool 7DU900PCDQ0
Whirlpool 7DU900PCDQ1
Whirlpool 7DU900PCDQ2
Whirlpool 7DU910PFGB0
Whirlpool 7DU912PFGQ0
Whirlpool 7DU920PWKB0 Undercounter Dishwasher
Whirlpool 7DU920PWKQ0 Undercounter Dishwasher
Whirlpool 7DU920PWKS0 Undercounter Dishwasher
Whirlpool 7ED0GTQXKQ00
Whirlpool 7ED0GTQXKQ01
Whirlpool 7ED0GTQXKQ02 Refrigerator
Whirlpool 7ED0GTQXMQ00 Refrigerator
Whirlpool 7ED20TKXDN00
Whirlpool 7ED20TKXDN01
Whirlpool 7ED20TKXDN02
Whirlpool 7ED20TQXFW00
Whirlpool 7ED20TQXFW01
Whirlpool 7ED20TQXFW02
Whirlpool 7ED20TQXFW03
Whirlpool 7ED20TQXFW04
Whirlpool 7ED20TQXFW05
Whirlpool 7ED22PQXDN00
Whirlpool 7ED22PQXDN01
Whirlpool 7ED22PQXFN00
Whirlpool 7ED22PQXFN01
Whirlpool 7ED22PQXFW00
Whirlpool 7ED22PQXFW01
Whirlpool 7ED25DQXFW00
Whirlpool 7ED25DQXFW01
Whirlpool 7ED25DQXFW02
Whirlpool 7ED25PQXDW00
Whirlpool 7ED25PQXDW01
Whirlpool 7ED25PQXDW02
Whirlpool 7ED27DQXDN00
Whirlpool 7ED27DQXDN01
Whirlpool 7ED27DQXDN02
Whirlpool 7ED27DQXDW02
Whirlpool 7ED27DQXFN00
Whirlpool 7ED27DQXFN01
Whirlpool 7ED27DQXFN02
Whirlpool 7ED27DQXFW00
Whirlpool 7ED27DQXFW01
  #2 (permalink)
Old 06-21-2009, 01:12 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool Incomplete model number
That model number is incomplete, it is 3-4 digits. Please post the complete model number so we can look it up to see what appliance you're dealing with and what components it uses which might be responsible for problems.
If the element was the problem it would have infinite resistance. Anything else and it is is likely good (or at least not the cause of a 'no heat' complaint).
Did you check the element's limiter switch? If open it would prevent the element from heating as well.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 06-21-2009, 02:57 PM
Junior Member
Default
Model from the data plate inside the warming drawer reads is 790.99013101. The unit is a Kenmore Elite Range. In the meantime I tested the voltage to that element and only saw 12-13 volts ac. I haven't checked the limiter
  #4 (permalink)
Old 06-21-2009, 07:54 PM
Senior Expert
APP Volunteer
Lightbulb Test limiter
I don't know how you are testing to get that reading. AFAIK the element should receive 240 volts or nothing.
Someone should because if the element is definitely good, either no power is getting to the element or the limiter isn't allowing it to reach the element.
BTW. If the element limiter is found to be defective the whole element will have to be replaced as the limiter is not available separately.
JFYI
Dan O.
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Surface element will not turn off rrb Oven Repair (including Ranges and Cooktops) 0 10-08-2009 01:06 PM
FRIGIDAIRE Surface element jrc140 Oven Repair (including Ranges and Cooktops) 1 05-20-2009 05:22 PM
Surface Element tractor1 Oven Repair (including Ranges and Cooktops) 6 09-12-2008 02:39 PM
Surface Element Repair lan68 Oven Repair (including Ranges and Cooktops) 4 02-08-2008 05:02 PM
Replace Surface Element gaitherjohn@hotmail.com Oven Repair (including Ranges and Cooktops) 0 01-31-2008 09:56 AM
