| » Gas Oven Valve |
Model Number: KGRC608 Brand: Kitchen Aid Age: 1 - 5 years
My gas oven stopped working. The burners still work. I looked through the posts, and think I've determined it is the valve/regulator. When I turn on the oven for either bake or broil, the ignitor glows bright orange but the oven does not fire up.
I looked under the oven, and have found the valve/regulator. Here's a link to the part -http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503808. The part is about $115 How do I know this is the problem prior to ordering the part? It's pretty expensive, so I don't want to order it if it's not the problem. Any suggestions on how to correctly diagnose? Thanks - Joe Ads By Google Related Models |
Quote:
You can find tips for locating the model and serial number identification tag on your appliances at the following link: LINK > Model Number Tag Location Guide Quote:
Quote:
Quote:
You can read about how such a gas oven ignition system works and the tests necessary to diagnose problems with it at the following link: LINK > Understanding Gas Oven Ignition Systems JFYI Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
thanks. I checked the current draw on the oven ignititor and sure enough its low, about 1/2 amp different from the broiler which never gets used.
Think of it as a "weak vacuum tube" the tube heater is weak. MANY THANKS, saved me a couple hundred $. |
| Display Modes | |
| Viking Oven Gas Valve Sticking | BIPD818 | Oven Repair (including Ranges and Cooktops) | 4 | 01-04-2010 11:09 PM |
| need new oven valve for very old stove | Miguelp1201 | Oven Repair (including Ranges and Cooktops) | 0 | 12-26-2009 10:20 AM |
| Oven safety valve | WALJ | Oven Repair (including Ranges and Cooktops) | 3 | 12-01-2009 03:19 PM |
| gas safety valve on oven? Can i replace this myself? | crazyoven | Oven Repair (including Ranges and Cooktops) | 0 | 11-05-2009 05:33 AM |
| Sticky oven gas valve? | farmingkarman | Oven Repair (including Ranges and Cooktops) | 0 | 03-01-2009 06:53 PM |
