Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Ron Butler (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/37733-ron-butler.html)
rsbutbut 06-20-2009 12:44 PM
Ron Butler
The Boiler Burner Woks Quite Well but the Bottom Burner has A Low Flame And it Has A Real slow Warm Up I Was on Line and you web sight show the Oven Safrty Valve Dual TYpe plus when burns the bottom burner you smell gas will this part cause the problem that I'm haveing because I Check all the line to bottom burner and they are clear.
Gene 06-20-2009 05:25 PM
Very likely the problem is a weak Bake igniter. Measure the current drawn by the igniter while it's "on" and if it's 2.5 amps or less than the igniter has to be replaced.
- The part number for the Bake igniter is AP2014008
Here are the breakdown diagrams and Replacement parts for GE JGBP33WES1 | AppliancePartsPros.com
