My contol panel does not work but the oven and burners work but does not heat up or get hot like they should,replaced control panel and still have the same proplem,Any ideas?
Pull the stove out, unplug it and remove the cover were the power cord connect to the stove. Look at the connections to make sure they are not burnt or loose.
i tried that suggestion and still the same problem ,any more ideas?
