Discuss
GE Profile Spectra XL44 Keypad/Front Panel Replacement
 in
Our GE Profile Spectra XL44 started having "F7" episodes. I followed the manual instructions (let it cool down, if still
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Profile Spectra XL44 Keypad/Front Panel Replacement
  #1 (permalink)
Old 06-19-2009, 11:59 PM
Junior Member
Dougg33 is on a distinguished road
Default GE Profile Spectra XL44 Keypad/Front Panel Replacement
Brand: GE   Age: 1 - 5 years
Our GE Profile Spectra XL44 started having "F7" episodes. I followed the manual instructions (let it cool down, if still a problem unplug for 5 minutes, plug back in) to no avail. Then I found some help here suggesting it's either the controller or the keypad. I unplugged the ribbon from the keypad to the controller and plugged the oven back in...No error. From the logic provided me, this means that the keypad is the problem. I ordered a new keypad for my exact model (which I don't have in front of me right now and I'm not at home). AppliancePartsPros had it out to me within days. I was all ready to install it, had everything disassembled, when I realized that the ribbon for the new front panel is on the opposite side from the old panel. If I'm looking at the oven from the front when it's assembled, the old ribbon connects to the controller on the left side. The new panel, when installed with the buttons in the proper orientation (not upside down), has the ribbon on the right side. The ribbon is not long enough to go through the slot, over the controller and plug into the other side. HELP!
It looks like the panel could have the ribbon come out on either the left or right sides...Do I need to specify this when I order?
What am I missing?!?
I checked with Customer Service and they sent me here.
Please help if you can...We need an oven!
Thanks so much for all the help!
Dougg33
Ads By Google
  #2 (permalink)
Old 06-20-2009, 04:22 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool Model number required
It means the keyboard *may be* the problem. The only sure thing that test would tell you is that if the error did return even while the keypad was disconnected, the keypad would not be the problem (ie. the control likely was).
No.
You either ordered the wrong part or received the wrong part.
Quote:
I don't have [my exact model] in front of me right now
That's too bad because that is the only way we can look into it. Posting the part number you received would also be necessary.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Spectra Xl44 Magsntrac Oven Repair (including Ranges and Cooktops) 2 09-25-2010 06:57 AM
GE SPECTRA XL44 gas tulsa28 Oven Repair (including Ranges and Cooktops) 1 01-22-2010 11:34 AM
Keypad / control panel removal & replacement Fireweed Oven Repair (including Ranges and Cooktops) 3 08-26-2009 09:37 PM
GE Profile Spectra stove -front panel installation judithjordan40@yahoo.com Oven Repair (including Ranges and Cooktops) 3 02-07-2009 01:02 AM
Next step, Control panel or keypad replacement? tgmeyer Oven Repair (including Ranges and Cooktops) 3 12-01-2008 04:09 AM
