Discuss
Oven does not go on
 in
Yesterday, I placed a prime rib steak in the broiler and after 3 minutes I went to check on it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven does not go on
  #1 (permalink)
Old 06-19-2009, 08:46 PM
kdavila59 kdavila59 is offline
Junior Member
kdavila59 is on a distinguished road
Default Oven does not go on
Model Number: RGB535BEA8WH   Brand: Hotpoint   Age: 5 - 10 years
Yesterday, I placed a prime rib steak in the broiler and after 3 minutes I went to check on it but it was not cooked. I turned the knob to ensure that the problem wasn't the oven but to my surprise I only saw the IGNITER-OVEN BAKE/BROIL on. The burner never lit after 3 or 4 minutes. The stove top burners do work. Does the top stove elements have anything to do with how the broiler or oven operates? I cleaned the burner with a brush hoping that the problem was it may have had residue from much broiling but it did not go on or make a difference.
Although, I read many posts with similar problems, I wanted to make sure that the feedback about the solution was indeed the answer.
Related Models
General Electric RGB535BEA8WH Gas range
General Electric RGB535GET1AD Gas range
General Electric RGB535GET1WH Gas range
General Electric RGB535GET2AD Gas range
General Electric RGB535GET2WH Gas range
General Electric RGB535GEV1AD Gas range
General Electric RGB535GEV1WH Gas range
General Electric RGB535GEV2AD Gas range
General Electric RGB535GEV2WH Gas range
General Electric RGB535GEV3AD Gas range
General Electric RGB535GEV3WH Gas range
General Electric RGB535GEV4AD Gas range
General Electric RGB535GEV4WH Gas range
General Electric RGB535GEV5AD Gas range
General Electric RGB535GEV5WH Gas range
General Electric RGB540SEH1SA Gas range
General Electric RGB540SEH2SA Gas range
General Electric RGB540SEH3SA Gas range
General Electric RGB628BEA1AD Gas range
General Electric RGB628BEA1WH Gas range
General Electric RGB628BEA2AD Gas range
General Electric RGB628BEA2WH Gas range
General Electric RGB628ET1AD Gas range
General Electric RGB628ET1WH Gas range
General Electric RGB628ET2AD Gas range
General Electric RGB628ET2WH Gas range
General Electric RGB628G1F0 Gas range
General Electric RGB628G1F1 Gas range
General Electric RGB628G1F2 Gas range
General Electric RGB628GEH1 Gas range
General Electric RGB628GEJ1 Gas range
General Electric RGB628GEJ2 Gas range
General Electric RGB628GEJ3 Gas range
General Electric RGB628GEN1 Gas range
General Electric RGB628GER1 Gas range
General Electric RGB628GER2 Gas range
General Electric RGB628GER3 Gas range
General Electric RGB628GEV1AD Gas range
General Electric RGB628GEV1WH Gas range
General Electric RGB628GEV2AD Gas range
General Electric RGB628GEV2WH Gas range
General Electric RGB628GEV3AD Gas range
General Electric RGB628GEV3WH Gas range
General Electric RGB628GEV4AD Gas range
General Electric RGB628GEV4WH Gas range
General Electric RGB628GF0 Gas range
General Electric RGB628GF1 Gas range
General Electric RGB628GF2 Gas range
General Electric RGB628GPH1 Gas range
General Electric RGB628GPJ1 Gas range
General Electric RGB628GPJ2 Gas range
General Electric RGB628GPJ3 Gas range
General Electric RGB629GEP1 Gas range
General Electric RGB630ET1WW Gas range
General Electric RGB630GES1 Gas range
General Electric RGB735WEL1WW Gas range
General Electric RGB735WEL2WW Gas range
General Electric RGB740BEH1CT Gas range
General Electric RGB740BEH1WH Gas range
General Electric RGB740BEH2CT Gas range
General Electric RGB740BEH2WH Gas range
General Electric RGB740BEH3CT Gas range
General Electric RGB740BEH3WH Gas range
General Electric RGB740BEH4CT Gas range
General Electric RGB740BEH4WH Gas range
General Electric RGB740BEH5CT Gas range
General Electric RGB740BEH5WH Gas range
General Electric RGB740BEH6CT Gas range
General Electric RGB740BEH6WH Gas range
General Electric RGB740BEH7CT Gas range
General Electric RGB740BEH7WH Gas range
General Electric RGB740GES1WH Gas range
General Electric RGB740GES2WH Gas range
General Electric RGB744BEA1AD Gas range
General Electric RGB744BEA1WH Gas range
General Electric RGB744BEA2AD Gas range
General Electric RGB744BEA2WH Gas range
General Electric RGB744BEA3AD Gas range
General Electric RGB744BEA3WH Gas range
General Electric RGB744GEH1 Gas range
General Electric RGB744GEH2 Gas range
General Electric RGB744GEH3 Gas range
General Electric RGB744GEJ1 Gas range
General Electric RGB744GEJ2 Gas range
General Electric RGB744GEJ3 Gas range
General Electric RGB744GEJ4 Gas range
General Electric RGB744GEJ5 Gas range
General Electric RGB744GEJ6 Gas range
General Electric RGB744GEJ7 Gas range
General Electric RGB744GEJ8 Gas range
General Electric RGB744GEJ9 Gas range
General Electric RGB744GEJA Gas range
General Electric RGB744GEN1 Gas range
General Electric RGB744GEN2 Gas range
General Electric RGB744GER1 Gas range
General Electric RGB744GER2 Gas range
General Electric RGB744GER3 Gas range
General Electric RGB744GET1AD Gas range
General Electric RGB744GET1WH Gas range
General Electric RGB744GET2AD Gas range
General Electric RGB744GET2WH Gas range
General Electric RGB744GEV1AD Gas range
General Electric RGB744GEV1WH Gas range
General Electric RGB744GEV2AD Gas range
General Electric RGB744GEV2WH Gas range
General Electric RGB744WEA1WW Gas range
General Electric RGB744WEA2WW Gas range
General Electric RGB744WEA3WW Gas range
General Electric RGB744WET1WW Gas range
General Electric RGB744WET2WW Gas range
General Electric RGB744WEV1WW Gas range
General Electric RGB744WEV2WW Gas range
General Electric RGB745BEA1AD Gas range
General Electric RGB745BEA1CT Gas range
General Electric RGB745BEA1WH Gas range
General Electric RGB745BEA2AD Gas range
General Electric RGB745BEA2CT Gas range
General Electric RGB745BEA2WH Gas range
General Electric RGB745BEA3AD Gas range
General Electric RGB745BEA3CT Gas range
  #2 (permalink)
Old 06-20-2009, 06:19 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
replace the bake ignitor coil. you said it came on, so that means the control is good and so is the gas valve. what happens is the get weak, and they can't open the gas valve. replace it, and you will have it. tom
  #3 (permalink)
Old 06-20-2009, 08:11 PM
Junior Member
Default
Thank you. I will do that and will get back to you on the outcome.
  #4 (permalink)
Old 06-20-2009, 08:14 PM
Junior Member
Default
Would you know the model number of the part needed?
  #5 (permalink)
Old 06-21-2009, 04:55 AM
Senior Expert
APP Volunteer
Default
The part # is WB13K21. Tom www.applianceeducator.com/parts,htm
  #6 (permalink)
Old 06-24-2009, 05:55 PM
Junior Member
Default
thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
