Just replaced the control panel #ap3043892 and still no display. Same as before, mash a pad and beep ,mash start and get a beep then three more beeps. Light pad still turns on oven light.????????
THIS FORUM IS DEAD!!!!!!! |
Denman, Do I need both boards ap5272198 & ap3598617 listed as # 3,or is the ap5272198(screen) enough? Thank you
Ap5272198 is the control board.
Looks like AP3598617 is the Sister Board which is used to control the door lock motor and latch so you should not need it. |
Denman, Thank you for your helpful advice. Wishing you a very Merry Christmas
