Discuss
gas oven parts
 in
I Am Looking For 2 Parts For This Tappan Gas Range. 1. Need The Piece Of Black Material Between The
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » gas oven parts
  #1 (permalink)
Old 06-18-2009, 12:27 PM
Junior Member
tcsans is on a distinguished road
Default gas oven parts
Model Number: 32-1002-23-01   Brand: Tappan   Age: More than 10 years
1. Need The Piece Of Black Material Between The Oven Handle And Oven Door Through Which The Fastner (screw) Travels
2. Need The Metallic Cap Overriding The Pilot Light Which Vents The Heat Out Through A Hole In The Stove Top
Any Ideas Would Be Appreciated
Related Models
Frigidaire 32-1002-23-01 (v13)
Frigidaire 32-1002-23-02 (v14)
Frigidaire 32-1002-23-03 (v15)
Frigidaire 32-1002-23-04 (v16)
Frigidaire 32-1002-23-05 (v17)
Frigidaire 32-1002-23-06 (v18)
Frigidaire 32-1002-23-07 (v19)
Frigidaire 32-1002-23-08 (v20)
Frigidaire 32-1002-23-09 (v21)
Frigidaire 32-1002-23-10 (v22)
Frigidaire 32-1002-23-11 (v23)
Frigidaire 32-1002-23-12 (v24)
Frigidaire 32-1002-32-01 (v13)
Frigidaire 32-1002-32-02 (v14)
Frigidaire 32-1002-32-03 (v15)
Frigidaire 32-1002-32-04 (v16)
Frigidaire 32-1002-32-05 (v17)
Frigidaire 32-1002-32-06 (v18)
Frigidaire 32-1002-32-07 (v19)
Frigidaire 32-1002-32-08 (v20)
Frigidaire 32-1002-32-09 (v21)
Frigidaire 32-1002-32-10 (v22)
Frigidaire 32-1002-32-11 (v23)
Frigidaire 32-1002-32-12 (v24)
Frigidaire 32-1002-45-01 (v1)
Frigidaire 32-1002-45-02 (v2)
Frigidaire 32-1002-45-03 (v3)
Frigidaire 32-1002-45-04 (v4)
Frigidaire 32-1002-45-05 (v5)
Frigidaire 32-1002-45-06 (v6)
Frigidaire 32-1002-45-07 (v7)
Frigidaire 32-1002-45-08 (v8)
Frigidaire 32-1002-45-09 (v9)
Frigidaire 32-1002-45-10 (v10)
Frigidaire 32-1002-45-11 (v11)
Frigidaire 32-1002-45-12 (v12)
Frigidaire 32-1002-57-01 (v13)
Frigidaire 32-1002-57-02 (v14)
Frigidaire 32-1002-57-03 (v15)
Frigidaire 32-1002-57-04 (v16)
Frigidaire 32-1002-57-05 (v17)
Frigidaire 32-1002-57-06 (v18)
Frigidaire 32-1002-57-07 (v19)
Frigidaire 32-1002-57-08 (v20)
Frigidaire 32-1002-57-09 (v21)
Frigidaire 32-1002-57-10 (v22)
Frigidaire 32-1002-57-11 (v23)
Frigidaire 32-1002-57-12 (v24)
Frigidaire 32-1002-66-01 (v1)
Frigidaire 32-1002-66-02 (v2)
Frigidaire 32-1002-66-03 (v3)
Frigidaire 32-1002-66-04 (v4)
Frigidaire 32-1002-66-05 (v5)
Frigidaire 32-1002-66-06 (v6)
Frigidaire 32-1002-66-07 (v7)
Frigidaire 32-1002-66-08 (v8)
Frigidaire 32-1002-66-09 (v9)
Frigidaire 32-1002-66-10 (v10)
Frigidaire 32-1002-66-11 (v11)
Frigidaire 32-1002-66-12 (v12)
Frigidaire 32-1004-00-01 Tap(v1) / Gas Range
Frigidaire 32-1004-23-01 Tap(v2) / Gas Range
Frigidaire 32-1007-00-01 Tap(v1) / Gas Range
Frigidaire 32-1007-00-02 Tap(v3) / Gas Range
Frigidaire 32-1007-00-03 Tap(v5) / Gas Range
Frigidaire 32-1007-00-04 Tap(v4) / Gas Range
Frigidaire 32-1007-23-01 Tap(v2) / Gas Range
Frigidaire 32-1007-23-02 Tap(v4) / Gas Range
Frigidaire 32-1007-23-03 Tap(v6) / Gas Range
Frigidaire 32-1007-23-04 Tap(v8) / Gas Range
Frigidaire 32-1008-00-01 Tap(v1) / Gas Range
Frigidaire 32-1008-00-02 Tap(v3) / Gas Range
Frigidaire 32-1008-23-01 Tap(v2) / Gas Range
Frigidaire 32-1008-23-02 Tap(v4) / Gas Range
Frigidaire 32-1009-00-01 Tap(v1) / Gas Range
Frigidaire 32-1009-00-02 Tap(v3) / Gas Range
Frigidaire 32-1009-00-03 Tap(v5) / Gas Range
Frigidaire 32-1009-00-04 Tap(v1) / Gas Range
Frigidaire 32-1009-00-05 Tap(v3) / Gas Range
Frigidaire 32-1009-00-06 Tap(v1) / Gas Range
Frigidaire 32-1009-00-07 Tap(v1) / Gas Range
Frigidaire 32-1009-00-08 Tap(v3) / Gas Range
Frigidaire 32-1009-00-09 Tap(v1) / Gas Range
Frigidaire 32-1009-00-10 Tap(v3) / Gas Range
Frigidaire 32-1009-00-11 Tap(v1) / Gas Range
Frigidaire 32-1009-23-01 Tap(v2) / Gas Range
Frigidaire 32-1009-23-02 Tap(v4) / Gas Range
Frigidaire 32-1009-23-03 Tap(v6) / Gas Range
Frigidaire 32-1009-23-04 Tap(v2) / Gas Range
Frigidaire 32-1009-23-05 Tap(v4) / Gas Range
Frigidaire 32-1009-23-06 Tap(v2) / Gas Range
Frigidaire 32-1009-23-07 Tap(v2) / Gas Range
Frigidaire 32-1009-23-08 Tap(v4) / Gas Range
Frigidaire 32-1009-23-09 Tap(v2) / Gas Range
Frigidaire 32-1009-23-10 Tap(v4) / Gas Range
Frigidaire 32-1009-23-11 Tap(v2) / Gas Range
Frigidaire 32-1012-00-01 (v1)
Frigidaire 32-1012-00-02 (v2)
Frigidaire 32-1012-00-03 (v3)
Frigidaire 32-1012-00-04 (v4)
Frigidaire 32-1012-00-05 (v5)
Frigidaire 32-1012-00-06 (v6)
Frigidaire 32-1012-00-07 (v7)
Frigidaire 32-1012-00-08 (v8)
Frigidaire 32-1012-00-09 (v9)
Frigidaire 32-1012-00-10 (v10)
Frigidaire 32-1012-00-11 (v11)
Frigidaire 32-1012-00-12 (v12)
Frigidaire 32-1012-00-13 (v13)
Frigidaire 32-1012-23-01 (v14)
Frigidaire 32-1012-23-02 (v15)
Frigidaire 32-1012-23-03 (v16)
Frigidaire 32-1012-23-04 (v17)
Frigidaire 32-1012-23-05 (v18)
Frigidaire 32-1012-23-06 (v19)
Frigidaire 32-1012-23-07 (v20)
Frigidaire 32-1012-23-08 (v21)
Frigidaire 32-1012-23-09 (v22)
Frigidaire 32-1012-23-10 (v23)
Frigidaire 32-1012-23-11 (v24)
  #2 (permalink)
Old 06-18-2009, 02:36 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Cool parts
The upper door trim looks to be part # 740T410P01 and appears to still be available.
LINK > 740T410P01 Door Trim, Upper (no picture)
I'm not quire sure what the second part is that you're trying to describe. If just the vent cover on top of the cooktop, it is part # 3132190 and looks to be discontinued.
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Parts for Old Oven TiffanyJ25 Oven Repair (including Ranges and Cooktops) 1 05-19-2009 09:49 PM
Help with finding parts for GE Oven Champaign Bob Oven Repair (including Ranges and Cooktops) 0 04-22-2009 06:51 AM
Some older oven parts = / extnctbrd88 Oven Repair (including Ranges and Cooktops) 0 03-19-2009 11:09 AM
oven seal parts for gaffers and sattler wall oven elka Oven Repair (including Ranges and Cooktops) 1 11-07-2008 02:38 PM
