Discuss
Thermador burner outer ring not heating up
 in
The rear left electric burner is a double ring. The outer ring doesn't heat-up. Only the inner ring
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador burner outer ring not heating up
  #1 (permalink)
Old 06-18-2009, 08:45 AM
DavidTherm DavidTherm is offline
Junior Member
DavidTherm is on a distinguished road
Default Thermador burner outer ring not heating up
Model Number: RES 30   Brand: Thermador   Age: More than 10 years
The rear left electric burner is a double ring. The outer ring doesn't heat-up. Only the inner ring heats up.
Is this something that can be fixed do-it-yourself?
Related Models
Thermador RES30
Thermador RES30QB PRIOR TO S/N 9708
Thermador RES30QB S/N 9708 & UP
Thermador RES30RS PRIOR TO S/N 9707
Thermador RES30RS S/N 9707 & UP
Thermador RES30W PRIOR TO S/N 9708
Thermador RES30W S/N 9708 & UP
Frigidaire RES34BNL1 Frg(v2) / Electric Range
Frigidaire RES34BNL2 Frg(v2) / Electric Range
Frigidaire RES34BNL3 Frg(v2) / Electric Range
Frigidaire RES34BNW1 Frg(v1) / Electric Range
Frigidaire RES34BNW2 Frg(v1) / Electric Range
Frigidaire RES34BNW3 Frg(v1) / Electric Range
Frigidaire RES36BFL0 Frg(v2) / Electric Range
Frigidaire RES36BFL1 Frg(v4) / Electric Range
Frigidaire RES36BFL2 Frg(v2) / Electric Range
Frigidaire RES36BFW0 Frg(v1) / Electric Range
Frigidaire RES36BFW1 Frg(v3) / Electric Range
Frigidaire RES36BFW2 Frg(v1) / Electric Range
Whirlpool RES6745PQ0 29" Electric Dryer
Whirlpool RES7646JQ0
Whirlpool RES7646KQ0
Whirlpool RES7646KQ1
Whirlpool RES7646KQ2
Whirlpool RES7646KQ3 29"electric Dryer
Whirlpool RES7648EN0
Whirlpool RES7648EN1
Whirlpool RES7648EN2
Whirlpool RES7648EQ0
Whirlpool RES7648EQ2
Whirlpool RES7648EW0
Whirlpool RES7648EW1
Whirlpool RES7648EW2
Whirlpool RES7648JQ0
Whirlpool RES7648KQ0
Whirlpool RES7648KQ1
Whirlpool RES7745PQ0 29"electric Dryer
Whirlpool RES7745RQ0 29"electric Dryer
Whirlpool RES7745RQ1 29"electric Dryer
Maytag RESF3330DB Range - S/c F/s Ele
Maytag RESF3330DW Range - S/c F/s Ele
Maytag RESF5330DT Range - S/c F/s Ele
Whirlpool REX2614LQ0 29"electric Dryer
Whirlpool REX3514PQ0 29"electric Dryer
Whirlpool REX3514RQ0 29"electric Dryer
Whirlpool REX3514RQ1 29"electric Dryer
Whirlpool REX3519PQ0 29" Electric Dryer
Whirlpool REX3614JW0
Whirlpool REX3614KW0
Whirlpool REX3614KW1
Whirlpool REX3614KW2 29" Electric Dryer
Whirlpool REX3614PW0 29" Electric Dryer
Whirlpool REX3614PW1 29" Electric Dryer
Whirlpool REX3614PW2 29" Electric Dryer
Whirlpool REX3615EW0
Whirlpool REX3615EW1
Whirlpool REX3615EW2
Whirlpool REX4625EN0
Whirlpool REX4625EW0
Whirlpool REX4625EW1
Whirlpool REX4625EW2
Whirlpool REX4634JQ0
Whirlpool REX4634KQ0
Whirlpool REX4634KQ1
Whirlpool REX4634KQ2 29" Electric Dryer
Whirlpool REX4635EN0
Whirlpool REX4635EN1
Whirlpool REX4635EN2
Whirlpool REX4635EQ0
Whirlpool REX4635EQ1
Whirlpool REX4635EQ2
Whirlpool REX4635EW0
Whirlpool REX4635EW1
Whirlpool REX4635EW2
Whirlpool REX5634JQ0
Whirlpool REX5634KQ0
Whirlpool REX5634KQ1
Whirlpool REX5634KQ2 29" Electric Dryer
Whirlpool REX5634PQ0 29" Electric Dryer
Whirlpool REX5634PQ1 29" Electric Dryer
Whirlpool REX5634RQ0 29" Electric Dryer
Whirlpool REX5635EN0
Whirlpool REX5635EN1
Whirlpool REX5635EN2
Whirlpool REX5635EQ0
Whirlpool REX5635EQ1
Whirlpool REX5635EQ2
Whirlpool REX5635EW0
Whirlpool REX5635EW1
Whirlpool REX5635EW2
Whirlpool REX5636AL0
Whirlpool REX5636AL1
Whirlpool REX5636AL2
Whirlpool REX5636AW0
Whirlpool REX5636AW1
Whirlpool REX5636AW2
Whirlpool REX6634PQ0 29" Electric Dryer
Whirlpool REX6634RQ0 29" Electric Dryer
Whirlpool REX6634RQ1 29" Electric Dryer
Whirlpool REX6646AL0
Whirlpool REX6646AL1
Whirlpool REX6646AL2
Whirlpool REX6646AL3
Whirlpool REX6646AQ2
Whirlpool REX6646AQ3
Whirlpool REX6646AW0
Whirlpool REX6646AW1
Whirlpool REX6646AW2
Whirlpool REX6646AW3
Whirlpool RF0100XKW0
Whirlpool RF0100XKW1
Whirlpool RF0100XRN8
Whirlpool RF0100XRW0
Whirlpool RF0100XRW1
Whirlpool RF0100XRW2
Whirlpool RF0100XRW3
Whirlpool RF0100XRW4
Whirlpool RF0100XRW5
Whirlpool RF0100XRW7
Whirlpool RF0100XRW8
  #2 (permalink)
Old 06-18-2009, 02:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
The problem could be a bad heating element, a bad switch for this burner or both of them. You have to have a simple multimeter to check the parts according to the wiring diagram.
Here are the breakdown diagrams and Replacement parts for THERMADOR RES30 | AppliancePartsPros.com
__________________
  #3 (permalink)
Old 06-21-2009, 12:55 PM
Junior Member
Default
How does the glass ceran stove top come off ??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Burner Not Coming On and Oven Not Heating gasco39 Oven Repair (including Ranges and Cooktops) 3 06-18-2009 04:47 PM
Range Burner Cap and/orTrim ring(are both needed?) Shirduffy Oven Repair (including Ranges and Cooktops) 2 06-01-2009 01:04 PM
Thermador no burner spark jjeaton2 Oven Repair (including Ranges and Cooktops) 1 04-22-2009 02:15 PM
Thermador XLO burner problem primorec Oven Repair (including Ranges and Cooktops) 3 02-12-2009 03:00 PM
Dual Burner - Inside ring not working. mtgappdrh Oven Repair (including Ranges and Cooktops) 0 11-21-2008 05:14 PM
