Discuss
Need to remove bottom door to replace inner glass.
 in
I need to replace the inner glass in the bottom oven door. I have the glass, but not sure how
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need to remove bottom door to replace inner glass.
  #1 (permalink)
Old 12-26-2007, 02:20 PM
FDAR FDAR is offline
Junior Member
FDAR is on a distinguished road
Default Need to remove bottom door to replace inner glass.
Model Number: KEHC309JBL05   Brand: Kitchen Aid   Age: 5 - 10 years
I need to replace the inner glass in the bottom oven door. I have the glass, but not sure how to remove the door. Any help would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-26-2007, 03:59 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
When you open the oven door, both hinges have a keeper that needs to be opened up so it keeps the tension on the spring so the door can be removed. Once the door is out, lay it on its face and remove the two screws on top and the two on the bottom holding the glass clips in place. This will separate the outer glass panel from the rest of the door. Then just pull whichever screws you need to replace the appropriate glass pane.
__________________
TechnicianBrian
TechnicianBrian.com
Appliance Repair Blog
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Directions to Replace GE Profile Glass Cooktop jeanss Oven Repair (including Ranges and Cooktops) 0 11-30-2007 06:57 AM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 04:42 AM
Remove & Replace Motor aaronstampley Dishwasher Repair 1 11-02-2007 11:57 AM
dishwasher leaking at bottom of door skinnybeak Dishwasher Repair 0 09-24-2007 06:22 PM
How to replace oven door glass? mkguitar Oven Repair (including Ranges and Cooktops) 3 09-11-2007 03:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
