My Dacor oven control panel is completely frozen and there is a red error code with the letters F O. This code isn't listed in the user manual and I have no idea what it means.
The "F0" error code according to the manufacturer instructions means: "Shorted Or Jammed Input Device". It says: "This failure will appear if a shorted or jammed input device is defective. Possible causes include shorted wires or a defective membrane switch".
Check the ribbon cable and the wires. If you need the correct part number for the membrane switch then post the serial number of the oven and the color of the membrane switch.
I have a Dacor dual fuel range that is having the same or similar issues. How do you take off the front panel? I am pretty handy, as we have apartments that I occasionally repair the appliances. Thanks for your help!!
What is the complete model number of the range?
