Discuss
No power to elements
 in
I have a Frigidaire model PLEM27S8CCB built in oven. It has power to the control panel but the elements won't
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No power to elements
  #1 (permalink)
Old 12-04-2011, 04:03 PM
Junior Member
rpdandy is on a distinguished road
Question No power to elements
Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire model PLEM27S8CCB built in oven. It has power to the control panel but the elements won't heat up. I have checked for continuity on the thermal switch and it read zero. I understand there is an inline circuit breaker and two thermal fuses (upper and lower) according to the wiring diagram. Where do I find these components on this model and wikk checking for continuity be sufficient?
Ads By Google
  #2 (permalink)
Old 12-04-2011, 05:34 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
I could not find a diagram for a PLEM27S8CCB, but here is one for a PLEB27S8CCB
Maybe the diagram will help you find the part your looking for.
Replacement parts for FRIGIDAIRE PLEB27S8CCB Frigidaire/electric Wall Oven | AppliancePartsPros.com
Did you already check this thermal switch?
FRIGIDAIRE Switch, Thermal, part number: AP2126993
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 12-04-2011, 06:52 PM
Junior Member
Question diagram
AJ,
Sorry about the typo. That is the right diagram but it doesn't show
AP3777386, AP3055316, or AP3055315. It's the same diagram I have. Gene had mentioned these components as possible culprits in another thread where a guy seemed to be having the same problem I'm having but on another brand. I checked the thermal switch and it read zero so I thought maybe my oven would have similar components.
  #4 (permalink)
Old 12-04-2011, 07:17 PM
Senior Expert
APP Volunteer
Default
Make sure the oven is getting 220-240 volts.
The control panel only needs 110-120 volts to work, but the heating elements need 220-240 volts.
Do you have a fuse box for the house or a breaker box?
If you have a fuse box it will have two fuses for the oven. If one house fuse it bad the oven would only be getting 120-120 Volts and that would be enough for the control panel to work, but not enough voltage for the heating elements to work.
If you have a breaker box for the house it still would not hurt to check for voltage at the oven were the power cord comes in to make sure you have the correct 220-240 volts. If you don't have the correct voltage and have breakers check the junction box the power cord goes to. I have seen wire nuts burn off and give problems.
Maybe Gene will have some other idea's too.
__________________
  #5 (permalink)
Old 12-05-2011, 06:26 AM
Junior Member
Default Re: no power to elements
Thanks AJ. I will check it out again.
  #6 (permalink)
Old 12-05-2011, 08:29 AM
Junior Member
Default
I checked the 220v outlet and the readings are between 22o and 247. When we checked across the thermal switch the wiring was still connected. Should I check all components after disconnecting them?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore range made loud bang and now no power to the oven elements Lisanepa71 Oven Repair (including Ranges and Cooktops) 0 03-07-2011 09:43 AM
No Power To Heating Elements djf343@gmail.com Oven Repair (including Ranges and Cooktops) 1 01-17-2011 05:12 PM
No Power To Oven Or Top Elements holapaw12 Oven Repair (including Ranges and Cooktops) 2 01-17-2010 09:56 PM
stove not getting any power to elements ckmrr Oven Repair (including Ranges and Cooktops) 0 11-22-2009 04:28 PM
No power to elements Keith M Oven Repair (including Ranges and Cooktops) 0 09-30-2009 07:48 AM
