| » Broiler Wont Shut OFF! |
Model Number: RBS305PDB14 Brand: Whirlpool Age: 5 - 10 years
While baking a cake in the oven last night, my oven threw a code (E2 - F3). I looked the code up and it said "Oven temperature too high (Cook Mode)" and that the fix was to replace the oven temperature sensor. So I did and the code is still there. What I didn't notice was that the broiler element glows red hot all the time even when the oven is off. I killed the breaker and left it off over night and when I turned it back on, it went back to glowing red hot. Do I have a bad element or is there something else wrong? Please advise?
Replacement parts for WHIRLPOOL RBS305PDB14 | AppliancePartsPros.com Here is the tech sheet https://www.servicematters.com/docs/...%208301757.pdf As far as I know can only be two things: 1. The wire fro the broil element to the control board has shorted to the case/frame so it gets power all the time re: 120 volts. But it should not get bright red as this requires the full 240 volts. 2. The broil relay contacts are welded together. You will need a new control board to fix this.
__________________
Quote:
Quote:
LINK > Whirlpool RBS305PDB14 Electronic Control It is also the only thing that should allow the broil element to be on at full power even when not in use. JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
| Display Modes | |
| Frigidaire Stove - broiler wont shut off | Peg529 | Oven Repair (including Ranges and Cooktops) | 3 | 02-15-2010 04:34 PM |
| GE Gas Range Broiler will not shut off | korybw | Oven Repair (including Ranges and Cooktops) | 1 | 08-14-2009 06:02 PM |
| Broiler in range will not shut off | Hayes | Oven Repair (including Ranges and Cooktops) | 1 | 05-29-2008 12:27 PM |
| Broiler will not shut off | RGunner | Oven Repair (including Ranges and Cooktops) | 3 | 05-08-2008 07:38 AM |
| Broiler will not shut off-With oven off | POTENTATE | Oven Repair (including Ranges and Cooktops) | 1 | 10-29-2007 05:10 PM |
