hi, i have an oven and microwave unit model JKP86SOH2SS. the microwave works well but the oven turns on and the temperature does not rise it sounds like if it is heating but it does not. can you help me to figure out whats wrong?
Originally Posted by: maggie2 hi, i have an oven and microwave unit model JKP86SOH2SS. the microwave works well but the oven turns on and the temperature does not rise it sounds like if it is heating but it does not. can you help me to figure out whats wrong
]hi, i have an oven and microwave unit model JKP86SOH2SS. the microwave works well but the oven turns on and the temperature does not rise it sounds like if it is heating but it does not. can you help me to figure out whats wrong
Could simply be a bad bake element. What I would do is disconnect the power to the range. Remove the bake element from the front of the oven and test it with my ohm meter to see if it was any good.
If could also bring the bake element to a appliance shop to have it tested if you can not test it yourself.
hi, thanks, for your advise, my husband cked the panel in the control section and found a flame sensor is the only one that is open. please advise. thanks.
Originally Posted by: maggie2 hi, thanks, for your advise, my husband cked the panel in the control section and found a flame sensor is the only one that is open. please advise. thanks. do you still think is the element.
